Wiper Blade/Insert Application Guide
Old 09-01-11, 04:50 AM
shoebopper
shoebopper's Avatar
Default Wiper Blade/Insert Application Guide
Has anyone seen the Lexus application guide for wiper blades and wiper inserts? Toyota has an accessible guide for this, but I can't seem to find the Lexus equivalent. A copy of the guides (or links) would be great!
***UPDATE***
Just to make something a wee bit clearer...I'm looking for the application guides for the wipers and inserts (and any other parts) that a DIY'er could consult for part numbers, not the "how-to" get it done. Toyota has a slew of application guide sheets for filters, wipers, you name it...I know Lexus kind of wants to hold that info close, but these app sheets probably hang in each of their garages for quick reference. The Lexus owners site has no references or links for them.
Old 09-01-11, 06:44 AM
jednav
jednav's Avatar
I have done it before. you have take the wiper blade off the wiper arm. no other way around it.
Old 09-05-11, 11:28 AM
JasDmw
JasDmw's Avatar
Just got a set of front refills at my local Toyota store. Parts guy took the blades off the RX, compared with the refills he had in stock, put them on and remounted the blades to the arms. Great service, under $20.00, tax in. Didn't have any rears in stock, but then, it doesn't get used that much so I am assuming it will last a while yet.
Old 09-05-11, 01:41 PM
infinirx
infinirx's Avatar
Just an offhand but related to wiper question. Does anyone know the thread pitch of that nut that the wiper is installed on?
Old 09-06-11, 08:06 AM
ycl1688
ycl1688's Avatar
Just to make life easier, buy the front wipers arm with rubber and metal backing, using the hook style one, take out the arm of the old ones and install the new ones, as easy and simple. I have been using the goodyear one from costco, michelin is as good. The last i check goodyear one is $8 each. Forget about the rubber insert, it is very flimsy to handle.
Old 09-06-11, 10:10 AM
mandyfig
mandyfig's Avatar
Get single blade wipers. I have the Bosch Icon, they are super.
Old 09-06-11, 10:11 AM
mandyfig
mandyfig's Avatar
The Goodyear from Costso is your best practical buy. For $8 per, single blade, you can replace them every year.
Old 09-06-11, 10:18 PM
infinirx
infinirx's Avatar
Thanks no need. I am taking off the rear wiper, and needed to know the inside thread so I could buy the right cover for it. Long story But the nut is 10mm from what I am reading no? If it’s a 10mm head size then it will be a M6 thread pitch I am pretty sure.
Old 09-07-11, 06:54 AM
ycl1688
ycl1688's Avatar
never done anything with rear one, it is seldom use, what is the procedure ?
Old 09-07-11, 07:47 AM
MerlinT
MerlinT's Avatar
Smile
+1
Here (Quebec City), Costco sells Michelin wiper blade. They're cheap and very good quality, so...
Old 09-07-11, 08:17 AM
ycl1688
ycl1688's Avatar
Originally Posted by MerlinT
+1
michellin wiper blades are sold in walmart in states.
Old 09-07-11, 01:12 PM
infinirx
infinirx's Avatar
It's really for shows. I would put it back on for daily driving. At shows allot of us try to remove the front and rear wiper for a cleaner look. It works well. But with the RX it's in the glass so it's kind of a pain to make it flush after removing the entire assembly. So I am putting a "plug" one might say, on it.
Old 09-07-11, 02:07 PM
mandyfig
mandyfig's Avatar
The rear wiper is a direct OEM replacement. Get the 14" (got mine from Advance Auto) and it looks identical. Follow procedure on how to replace.
The whole piece is replaced, not only the rubber insert.
Old 07-19-14, 09:44 AM
devere1000
devere1000's Avatar
Red face rear wiper replacement on a 2010 lexus rx 350
This wiper is hard to access. You need to turn car on and rear wiper on. Turn car off when wiper is in the down position. Pull the wiper arm up from rear window. It won't come up too far since the spoiler is in the way. Swing the blade away from the arm as far as it will go. Gently pull the blade off the arm. It should pop off. I used a michelin 16" replacement arm. It fit perfectly.
ObsidianBl
GX - 2nd Gen (2010-2023)
44
05-06-23 09:41 AM
ELEX470
03-13-15 07:47 AM
Dyslexi
RX - 1st Gen (1999-2003)
03-31-11 05:04 PM
UCrazyKid
IS F (2008-2014)
11-24-10 04:14 PM
bagsbie
01-15-10 11:16 AM
Quick Reply: Wiper Blade/Insert Application Guide
