2008 RX 350-No Outlet Power
Old 07-17-14, 11:45 AM
H2013
H2013's Avatar
Question 2008 RX 350-No Outlet Power
All of a sudden, all 3 of my outlets for charging stopped working...can't charge my cell phone!!! Any suggestions?
Old 07-17-14, 01:21 PM
pbm317
pbm317's Avatar
check the fuses? seems simple enough to check
Old 07-18-14, 05:04 AM
smassey321
smassey321's Avatar
That seems odd as all 3 each have their own fuse. When you say 3 you are talking front of shifter, below shifter and hatch right? You sure your charger is good?
Old 07-18-14, 07:39 AM
gundy
gundy's Avatar
I am having the same problem with the 2005 RX 330 I just purchased. If the power outlet locations are the same as mine, there is one just above the shifter on the dash, one in the floor tray under the center dash and one in the trunk. I think the main culprit for me is the outlet in the trunk. I checked the two fuses for the outlets in the fuse box under the dash/steering wheel and both were blown (is there one also under the hood for the back?). I replaced the fuses and both front outlets worked fine. I then went to the trunk and tested that one. After providing power for a few seconds, it stopped and I found the fuse for the outlet in the bottom tray was blown again! So something else to get fixed. If you do replace the fuses yourself (which is quite easy), the lid of the fusebox under the hood should have spare fuses and a fuse pulling tool for removing the fuses. IMPORTANT: make sure you get the correct fuses as there are several different ones in my RX 330 (they can't make it easy). The fuses in the box under the dash are the "mini low profile flange" type. It's probably easiest to just take the blown fuse that you are replacing with you to the auto parts store for comparison. Good luck.
Steve G.
Old 07-20-14, 08:41 PM
H2013
H2013's Avatar
Chargers are good. Checked the fuses but hard to tell if they are blown per the manual. Possible they blew as power outlets could not handle charging a phone and playing a personal DVD player.
Old 07-21-14, 05:43 PM
Briand_OH
Briand_OH's Avatar
Um, a BTDT on a 99 RX300 and 98 GS400:
I've had to disassemble the actual receptacles and replace a redundant "fuse" washer that failed under 7 Amp+ use. It might be on a thread on one of those forums. A freebie Harbor Ft. DVM is worth what you pay for it in diagnosing. Agree that checking regular fuses is good first step....
Old 07-30-14, 12:18 PM
H2013
H2013's Avatar
Default Thanks
Mechanic found blown fuse. Blamed it on a faulty car phone charger...which works fine in 2 other cars. Replaced the fuses and bought a cheap, new phone charger. So far, so good.
Old 08-20-14, 12:25 AM
JJsRX350
JJsRX350's Avatar
Sometimes a penny will fall into the cig lighter and blow the fuse. I have seen it happen many times.
DennisMik
06-27-19 11:59 AM
jimmad
11-20-17 07:10 PM
PETERPHAN8
RX - 3rd Gen (2010-2015)
09-04-14 09:33 AM
drewcam888
04-01-12 11:19 PM
ericg
10-21-08 09:14 AM
Quick Reply: 2008 RX 350-No Outlet Power
