Manual shifting of 2005 RX 330 with automatic transmission?
Old 07-21-14, 09:26 AM
gundy
gundy's Avatar
Default Manual shifting of 2005 RX 330 with automatic transmission?
This is probably a stupid question but I'm going to ask it anyway.
I see a lot of cars with automatic transmissions that also have a sport/manual mode that allows the driver to manually shift into different gears at will. Since my 2005 RX 330 w/4WD has the ability to select gears L through 4 (plus D w/overdrive), is it safe to manually shift through these gears when driving, similar to the aforementioned, without damaging the transmission? Thanks.
Steve G.
Old 07-21-14, 01:10 PM
pauljcl
pauljcl's Avatar
Yes, you can do it. Probably not worth the effort - we are not talking 'sport' here. I had read somewhere that some people recommended using "4" instead of D in town - it was said to prevent the use of the overdrive and thus reduce wear on the transmission. [I would have to check my gearshift to be sure - but you would put the gearshift lever on the left as opposed to the right in D. I don't do it.
Old 07-21-14, 05:49 PM
satz
satz's Avatar
as paulcjl said above you can do it, but it's definetely not a sport mode. The changes are not very quick. However I do use it sometimes when coming down long steep hills, to keep it in 3rd or 4th to use some engine braking.
Also occasionally when I want to drive enthusiastically, I'll use it to keep the gear I want when exiting a corner fast
PWMDMD
RX - 4th Gen (2016-2022)
03-14-19 08:43 PM
WendyATX
03-29-17 04:06 PM
LexusRCF15
RC F (2015-present)
03-27-16 07:12 PM
Juni14Ayal
RX - 3rd Gen (2010-2015)
31
03-28-14 04:09 AM
gridlock13
06-30-09 03:33 PM
Quick Reply: Manual shifting of 2005 RX 330 with automatic transmission?
