Airbox - captive nuts - where can I find?
Old 07-31-11, 05:43 PM
ahbuhjee
ahbuhjee's Avatar
Default Airbox - captive nuts - where can I find?
I was replacing my air filter the other day and pressed a bit to hard on the 10mm bolt, forcing the captive nut on the other side to drop out of its pressing and to be lost forever. Has this happened to anybody before? Is there a captive nut I can replace this with?
Thanks in advance!
Old 08-01-11, 05:37 AM
nwfsnake
nwfsnake's Avatar
Same thing happened to me, but I was able to retrieve it with my long magnetic parts picker. Not a great design. I looked at a couple of the online parts catalogues, but it appears you cannot buy them without purchasing the entire airbox (ouch!).
Old 08-01-11, 06:14 AM
mandyfig
mandyfig's Avatar
Must agree it so tight in there and they should have just done a clip on type.
Really sucks. I dread changing my filter.
So when you do it, be slow and take time. And yes you will have to buy the box if you wanted to change it.
Old 08-01-11, 10:54 AM
ahbuhjee
ahbuhjee's Avatar
Default Airbox
the dealer quoted me $700 for the box! Anybody know what size nuts I can use instead?
Old 08-01-11, 11:01 AM
lexus114
lexus114's Avatar
$700.00 for a friggin plastic box.
Old 08-01-11, 07:43 PM
HtownBlue
HtownBlue's Avatar
You can go to almost any hardware or autoparts house and get the nut you are looking for.
I think (don't qoute me) it is a 10 mm 1.0 pitch. Take the bolt and find a nut that matches it. Should be a simple find.
Old 08-02-11, 03:14 AM
nwfsnake
nwfsnake's Avatar
The socket for the bolt is 10mm, but the thread size is 5mm by either 0.8 or 0.9.
Old 08-02-11, 04:44 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
try junk yard / recycled parts?
Old 08-02-11, 07:43 PM
RX330inFL
RX330inFL's Avatar
http://lexus.sewellparts.com/oem-cat...X330-2004.html
Old 08-02-11, 11:53 PM
RuninRoach
RuninRoach's Avatar
nuts in captivity eh........an asylum would be first place to look....and if that doesn't work, you can always refer to the parts diagram in the above post and tell us which one you lost....
Old 08-03-11, 12:07 AM
RX330inFL
RX330inFL's Avatar
Actually, if you notice in the diagram you cannot order the ones they show.
Old 08-03-11, 10:20 AM
RuninRoach
RuninRoach's Avatar
not from here, but if we know which ones i will do my darndest (is that a word) to try and find it for him on Google
Old 08-15-11, 07:11 PM
ahbuhjee
ahbuhjee's Avatar
Unfortunately junk yards try to price their product relative to list price. 50% of list price is still a big number.
I don't think the nut I'm looking for is marked in that diagram. Its basically the nut that the bolt labeled N1 in the top diagram, fits into. It fits into the front part of the lower airbox.
Thanks for the ideas/replies so far however
Old 03-03-12, 11:06 AM
ovrpar6
ovrpar6's Avatar
Default 10mm bolt
has anyone ever found the replacement bolt for this posting?
Two people but up specs on the bolt but they are not consistant. Which is it??????
Old 07-23-14, 07:42 AM
Noozboy
Noozboy's Avatar
Default Lexus RX 330 Airbox
I'm a little late to the party, but for those who struggle finding captive bolts/screws for the Lexus air filter box (Airbox) there are (at least) a couple of ways to go. If you don't want to pay high dealer costs, eBay has the captive bolts for $11/each. Ouch!
However, if you have a great Ace Hardware store near you, like I do, Ace is the place. Found great help in the Ace aisles with a car-guy named JT. With JT's help, I just replaced the captive bolts with a metric M5 25mm stainless steel screw. Couple that with a neoprene-backed stainless washer and voila! Works like a charm to hold the airbox together.
Cost $1 for each screw and washer combo. I needed two, so it cost me just over $2.
Thanks for the earlier advice on the forum, but a special thanks to Ace Hardware for finding a great solution at a killer cost.
netlander (07-18-20)
Quick Reply: Airbox - captive nuts - where can I find?
