Misfire on cylinder #3...already swapped coils
Old 07-16-14, 07:12 PM
Grip
Grip's Avatar
Default Misfire on cylinder #3...already swapped coils
Code: P0303 Misfire on cylinder #3.
Swapped coil from cylinder #3 to cylinder #6 and fuel injector from #3 to #2.
Shows misfire is still on #3. Plug looks normal tan brown.
#3 is the middle cylinder closest to the firewall I take it.
Any suggestions?
Old 07-17-14, 07:58 AM
Rainbird
Rainbird's Avatar
Did you clear the OBD code after the swap?
Old 07-17-14, 10:26 AM
Grip
Grip's Avatar
Yes I did.
Old 07-19-14, 05:51 PM
Wht95scort
Wht95scort's Avatar
Is this a 330 or 350?
Old 07-19-14, 06:02 PM
kiwi
kiwi's Avatar
perhaps a compression test / cylinder leak down test is in order
Old 07-19-14, 08:26 PM
HtownBlue
HtownBlue's Avatar
You may have too much or too little air getting into the cylinder. Also a clogged injector or foiled injector would cause this issue. Compression test would be in order as well just to make sure.
Do those and report back.
I would bet good money you don't respond back and tell the community what the issue was though.
Old 07-20-14, 08:40 PM
Grip
Grip's Avatar
Yeah I'm not like one of those idiots lol. Couldn't believe how many threads on this forum had no resolution posted.
Muscle car guys ALWAYS come back and report findings.
Failed compression test. Garage said it's a burnt exhaust valve. GAH!!
Oh wait...it's not my car anyways.
Old 07-29-14, 07:29 AM
Grip
Grip's Avatar
So now it looks like it will need a complete rebuild. Head came off and exhaust valve is burnt but they think piston rings are shot too because motor ran low on oil....from rubber hose oil line failure a couple of months ago.
What a POS design.
Speedy0o
09-20-23 08:46 AM
JimboGo
04-26-18 06:12 AM
05RX330AWD
07-10-17 10:19 AM
badabing1
04-24-12 08:15 PM
killerbyte
04-17-12 02:43 PM
Quick Reply: Misfire on cylinder #3...already swapped coils
