2007 RX350- What Tire Pressure for 18 inch rims ?
I got rx350 with stock OEM 18 inch rims.
Today I bought Micheline Premier A/S.( all season tires).
What tire pressure should I maintain ?
I know manufacturer recommends 30 psi, but that is just for 17 inch.
Advices are highly appreciates.
Cheers.
Cheers.
Lexus has 35 psi on the sticker for 18 inches, but I like to go halfway between that and the tire's listed load. It means I'll still be matching spec if any tires are running "low."
If you don't have your manual or sticker you can always refer to the documentation on the Lexus Drivers site.
Link to specifications for the 2007 RX350:
http://drivers.lexus.com/t3Portal/do.../sec_06-01.pdf
Keep the same pressure. Just check your tires because, as you state, the pressure will increase when the temperature rises and you need to re-adjust. Similarly, in winter, you will need to add air to maintain the pressure, if the temperature differential between summer and winter is great.
31 - 32 is perfect for comfort and tire wear. When I load up for road trips I go to 35 but I don't leave it there as it wears the center of the tire faster than the edge. I have an awd 400h which is heavier than the other RX models.
Tire wear also depends on the tire model. The Michelin Energy has a soft edge so I could run at 34 all the time with those and the tire wore evenly. My current Michelin Latitude has a harder edge and they are wearing evenly at 32 psi.
How do you like the Michelin Premier A/S so far? I thought about getting that last week but local Costco didn't have that in stock so I went with the same Michelin MXV4 I had before.
