4 Wheel alignment
Old 07-22-14, 06:45 AM
User 41924
User 41924's Avatar
Default 4 Wheel alignment
A couple of weeks ago, I noticed that my '11 IS350 wasn't tracking right, so I decided it needed to be aligned. The truth is, it was probably the highway I was on that had lots of seams and was well worn. The local dealer (that I REALLY like) quoted me $140 for a 4 wheel alignment, and Brakes Plus was only $60. Guess where I took it It turns out that the camber for the left rear is within spec, but off a bit in one direction. The right rear is (barely) within spec but off in the other direction. I was told that the difference between the two could be why I was tracking funny. Maybe, maybe not, but OK.
The thing is, there is no adjustment for camber in the back wheels! With no camber adjustment, I have to wonder if tow in is adjustable. There wouldn't be any caster adjustment on the back wheels, would there? Of course, Brakes Plus wanted me to spend $400 to install a piece that would allow adjustment for camber, but I chose to leave it alone.
My question is ..... does anyone know if the tow in on the rear suspension of an AWD IS is adjustable? What exactly is the point of a 4 wheel alignment, if it isn't? And .... does it matter?
Old 07-22-14, 09:42 AM
sm1ke
sm1ke's Avatar
Toe in the rear is adjustable with the OEM components, to a certain degree. Many people report having a rear end wobble when accelerating from a stop after they've lowered their AWD IS.. I also had it, but after getting an alignment with the OEM components and minimizing the toe as much as possible, there was a significant decrease in the wobble, to the point where I would only experience it if I was accelerating hard off the line.
Stealth19
ES - 5th Gen (2007-2012)
19
08-07-22 08:07 PM
MIC123321
08-23-15 08:39 AM
pearllex09
04-05-14 01:57 AM
Stevoe88
Suspension and Brakes
07-27-11 12:31 PM
Kharizma
04-29-06 01:32 PM
Quick Reply: 4 Wheel alignment
