New Owner with a few questions.
Old 07-22-14, 02:53 PM
robtwo
robtwo's Avatar
Default New Owner with a few questions.
I did try searching but didn't find any answers to my questions.
1. Do the 2011 IS250’s have carbon build up problem?
2. Tranny service – I see no mention of changing the fluid in the service schedule. Is it required?
3. Why are spark plugs changed at 60K? Most companies are 100K now.
4. How do I program my remote to lower the windows?
Thanks guys!
Rob
Old 07-22-14, 02:59 PM
NikonGuy
NikonGuy's Avatar
1. Don't know
2. Lexus says it is lifetime fluid, for me I would change it at 100K or earlier to be safe.
3. Don't know, all I know is it is a bugger to get to
4. Should be programmed already. Hold down lock button on fob for a few seconds
Old 07-22-14, 03:11 PM
darkdream
darkdream's Avatar
I believe all IS250s have the carbon build up problem.
Old 07-22-14, 09:30 PM
idoke1
idoke1's Avatar
I think all is250s has carbon issues. Lifetime tranny fluids. The oem spark plugs are rated at 100k miles but most change out @60k miles for better gas mileage. Windows going down should be already programed. I believe you hold on to the unlock button on your key remote for a couple of seconds to use that feature. Programing it? Never did and don't know.
Old 07-23-14, 05:27 AM
Sffd103
Fire Slayer
Sffd103's Avatar
I'm guessing that the 11's are still too new to have thr build up. Most have the older models.
Here's a link to changing the differential fluid. It says in the manual if you look what you're supposed to do and I believe it's a sealed transmission and you're not supposed to change it. It also tells you to change the plugs at 60K.
https://www.clublexus.com/forums/is-...hange-diy.html
THE.K.W.C
12-11-20 09:24 PM
babyduke
ES - 5th Gen (2007-2012)
14
05-24-17 11:23 PM
Nauticalx
04-07-08 11:27 AM
his_eminence
Maintenance
02-20-02 05:34 AM
Juan C. Cos
Maintenance
13
05-27-01 02:40 PM
Quick Reply: New Owner with a few questions.
