Trip Reset after refuel
hey everyone
I used to drive an Acura which had an option to have the trip computer automatically reset each time after refuel. I spoke to my dealer and they mentioned that this is an option.. I was able to get the 'range' to display be default but haven't been able to figure this out yet. Thanks in advance for anyone that knows the answer.
Press the ODO trip button on your lower left side until desired trip (A or B). Hold it down to reset it.
Does this answer your question? I'm not sure if this is what you were exactly looking for. I guess this is not 'automatic'.
Thanks for the response. I'm aware of the ability to reset like that but was looking for something that will reset automatically once I drive away from the pump. It keeps track of the km travelled on that particular tank
The GS has various displays that you can run through with steering wheel buttons, and one prompt is "mileage after refueling". If I keep it in that mode it automatically tells me the MPG I'm getting since the last tank of gas. It automatically resets after I fill up. Does the IS not have this?
Would have to play around with the cluster display more as I remember there being two Distance displays. I know one is Range (miles/km left on tank - reverse of what the OP wants) and I think the other is distance driven since Start. Not sure why someone would want the last one but that's also the one I'm not too sure on. Too lazy to go check right now.
What the car does do automatically that I'm surprised more people don't take advantage of is mpg After Refuel. Most of the pictures and posts I see posted here is people using is mpg After Reset.
So the car does auto-MPG but I don't think it keeps tabs of how many miles/km you drive per tank and then automatically resets that counter.
Edit... Arrow over to the Settings Tab (gear icon) and then you can change Drive Info 1 and 2. Then that information displays on the i tab and is what you step through when using the arrow keys on the right side of the steering wheel. Figured I should probably clarify on that.
Your post is part of why I posted. You referenced the GS and asked if the IS had this so I answered the question and addressed the OP at the same time.
