Random Start Up Issue
Old 07-31-14, 09:09 AM
robtwo
robtwo's Avatar
Default Random Start Up Issue
I've got an '11 250AWD, 48K on the clock CPO purchase. Only had it for a month.
It's been pretty hot around here and I've noticed randomly the car starts up with a less than smooth idle. This ONLY happens if I've been driving the car, stop and restart it about 10-15 minutes later. A quick on/off/on does not produce any problems.
Outside temps are 80f+
No CEL has appeared so I figure a dealer visit is worthless. Am I correct in assume the intake temps are just so high the ECU has trouble calibrating? I'd gather intake temps are approaching 150-180 degrees based on my past experience with modifying/tuning cars, though I'm not logging anything on this stock car. Of course this goes away quickly.
My only other thought is this is carbon build up.
Old 07-31-14, 11:58 AM
Gville350
Gville350's Avatar
The car should not have any issues started back up when warm/hot. Do you have a healthy battery and good cables going to it?
Old 07-31-14, 01:39 PM
DryEye
DryEye's Avatar
You could try disconnecting the battery for 10 minutes to reset the ECU.
Old 07-31-14, 05:13 PM
robtwo
robtwo's Avatar
Yes, all stock.
lexag12
12-06-15 07:33 AM
mblottma
04-15-15 09:47 PM
King700se
11-26-14 10:01 PM
attzor
Performance & Maintenance
03-31-10 09:29 PM
818GS
10-11-09 10:45 PM
Quick Reply: Random Start Up Issue
