Trunk Opener Release Not Opening
Old 05-17-04, 06:44 PM
93ES300BCB
93ES300BCB's Avatar
Default Trunk Opener Release Not Opening
My 93 ES300 sat in a parking lot for six months while I was deployed overseas in the Navy. When I returned, the trunk release switch on the driver's door (next to the fuel door release) was not working. I have manipulated the yellow disable in the glove compartment and it still doesn't work. Two wires lead to the trunk release. I disconnected one of them and the alarm went off, is this the same power supply as the trunk release? Manual operation using the key works fine. I've seen other threads recommend checking the fuse. Which fuse is it? The fuse holder label plates/owner's manual don't give any indication. The button feels fine (not too loose/stiff) and the fuel door release works fine. Are those two powered off the same fuse?
Brendan
beer@alum.mit.edu
Old 06-10-04, 10:49 AM
chick_ny
chick_ny's Avatar
Exclamation me too
I have the same problem just one day it just stop working .... i think im going to buy the repair manual its driving me crazy
Old 06-10-04, 09:38 PM
93ES300BCB
93ES300BCB's Avatar
Unhappy Solution
I ended up jiggling the housing for the button in the glove compartment and the door button began working intermittently. I think there is a loose/grounded connection somewhere.
Brendan
Old 06-11-04, 06:20 AM
chick_ny
chick_ny's Avatar
Lightbulb mmmm
i'll try that ....good luck to me
Old 06-12-04, 02:12 PM
TCwindom
TCwindom's Avatar
i have this problem as well... but haven't attempted to fix. what's this in the glove compartment you speak of?
Old 06-13-04, 10:16 PM
AusLex300
AusLex300's Avatar
Does anyone know what number fuse the trunk is? Mine decided not to work a few days also..
Chris
Old 06-13-04, 10:38 PM
juan01
juan01's Avatar
There's a trunk release button in there... If you push it down, the trunk won't be able to open from the switch on the door, only through a key. I found this out when I thought my trunk was stuck too, but it was just the button.
Old 06-14-04, 07:16 AM
chick_ny
chick_ny's Avatar
Lightbulb hahahahah
yeah the same thing for me ....all i had to do is press the button
Old 06-14-04, 09:14 AM
juan01
juan01's Avatar
LOL!!! Glad you found the fix.
JasonBrods
01-24-20 10:24 AM
GqFletes
03-12-18 08:01 AM
molly1020
07-02-08 06:26 PM
rogerw11
11-15-03 02:53 PM
EastCoastES
12-11-02 01:09 PM
Quick Reply: Trunk Opener Release Not Opening
