Fuel Filler Door Repair
Old 08-08-04, 02:10 PM
kumaran_b
kumaran_b's Avatar
Default Fuel Filler Door Repair
My fuel filler door is broken(some spring fell off) and need to manually open the door using the lever from the trunk. Does anyone know where I can get the part to replace this other than asking the dealer.
Thanks
Old 08-08-04, 07:41 PM
lexusk8
lexusk8's Avatar
I ran into the same situation with my prior '96 ES. Clumsy me accidentally snapped off the fuel lid door when taking out the gas pump after filling up at a station As a temporary fix, I drilled out 2 holes on the broken door and used electrical wiring as hinges for the door. Later on I ended up buying myself a new door at the dealership (costed about $125 including paint). Unfortunately this is the only way I know of where to get that particular part for replacement, so best of luck.
Old 08-09-04, 12:43 AM
NeverSatisfied
NeverSatisfied's Avatar
My parent's '98 ES fuel door spring-thing popped off while washing (yes, ALL jambs are wiped dry!), and was easily replaced with a new spring-thing; didn't have to buy the whole door.
Old 08-09-04, 05:42 PM
aimsoft
aimsoft's Avatar
The spring is only 8$ at the dealership. they didnt ask for any labor charges... Its fairly simple...
Old 08-10-04, 12:30 AM
George Hsieh
George Hsieh's Avatar
I had the same problem. I went down to the dealer, they told me the thing that hold the spring in place can't be fix... the whole door must be replace... so... I don't know... until now I haven't fix that.. but if anyone have any good idea how to fix it place post ...... thank you
ThumperPup
ES - 5th Gen (2007-2012)
19
03-02-22 01:04 PM
Snowrydr01
10-05-15 01:32 PM
Saraabadie
06-19-13 06:37 AM
extender33
10-18-06 09:59 AM
Quick Reply: Fuel Filler Door Repair
