steering rack bushings...
Old 01-12-05, 11:33 AM
indypwr
indypwr's Avatar
Default steering rack bushings...
anyone knows how many do we have on our cars?
hasanyone tried replacing them?
Old 01-12-05, 11:50 AM
jeremyp111
jeremyp111's Avatar
There are two steering rack bushings that go where the bolts mount it to the frame and one large one for a total of three. The large one is available from Toyota and the other 2 are available from Andrew Vlamos, vftbushes.com. Hope this helps.
Old 01-12-05, 11:56 AM
sourcemine
sourcemine's Avatar
how do you know when they go bad?
symptons?
Old 01-12-05, 11:58 AM
jeremyp111
jeremyp111's Avatar
If your steering feels loose then it's most likely the rack bushes. Get under the car with a pry bar and pry on the mounting areas to see if there is any play. It should be really tight (obviously). Use the pic above as a reference.
Old 01-12-05, 12:03 PM
indypwr
indypwr's Avatar
tks for that feedback. do you know what part nbr for the toyota part?
i will check with andrew for the rest.
Old 01-12-05, 12:06 PM
jeremyp111
jeremyp111's Avatar
I don't. Sorry.
indypwr
indypwr's Avatar
i get this "dead" steer everytime i turn....u know what i mean?
i turn the wheel slight degrees and the car does not turn. there is a "dead" spot in between
when turning both left and right...........it sucks and "dangerous"!!!
Old 01-16-05, 05:58 PM
mteele
mteele's Avatar
If someone can get that part number for the Toyota bushing, I would REALLY appreciate it.
Old 01-16-05, 10:22 PM
indypwr
indypwr's Avatar
i know, i need that part nbr as well.
Old 01-17-05, 12:44 AM
JamesN
JamesN's Avatar
My steering feel loose only when I'm on the freeway. Does that mean the steering bushing is bad also??
Old 01-17-05, 04:10 AM
jeremyp111
jeremyp111's Avatar
Print this out and bring it to your dealer to get a price. It's the grommet in the bottom left of the pic.
Old 01-18-05, 12:18 AM
indypwr
indypwr's Avatar
tks buddy!!!
Old 01-19-05, 06:49 AM
VSsc400
VSsc400's Avatar
i unded up getting VFT bushings instead of lexus OEM. Installation was easy. only the bottom 2 bushings were bad. one of the in fact was barely there. It had disintegrated almost completely.
took like 15 minutes for the whole thing (i had access to a lift and tools)
Old 01-23-05, 03:50 AM
Streamline
Streamline's Avatar
I'm currently experiencing the same problem. The top of the steering wheel will end up at roughly the 10 and 2 o'clock position before any real "turning" is experienced.
Have you had a diagnosis on what the problem is?
I am suspecting it is one of two issues.
1) The steering rack itself is going bad.
2) The power steering pump is leaking (which is the case w/ my car). HOWEVER...I don't think this is truly the problem as steering is fine. It is not like the "power steering" is on and off.
Any ideas?
Old 01-23-05, 12:48 PM
indypwr
indypwr's Avatar
i finally ordered the bushings thru andrewvlamos.com . paid 79.00 shipped. will post pics when it arrives.
Quick Reply: steering rack bushings...
