What octane gas do you use? (The Mother thread)
Old 12-23-05, 10:36 AM
Tammy
Tammy's Avatar
No deleterious (harmful) effect..
Old 12-26-05, 10:11 AM
denverdog
denverdog's Avatar
just for the record, midgrade in denver is 87 octane.
Old 12-26-05, 10:42 AM
damon
damon's Avatar
If you hear no audible knocking then you are not doing damage to the engine. There is no difference in the cleansing capacities between different grades of fuels so don't buy into that argument either. Lower grades will not clog your fuel injectors.
Old 12-26-05, 11:17 AM
sphereman
sphereman's Avatar
i use regular (87 in california, the lowest grade) on all my Lexus (brand new 05 LS and 98 LS as well). i don't think there is any harmful effect (or so i hope )
Old 12-26-05, 12:48 PM
denverdog
denverdog's Avatar
regular is 85. everything is different at altitude.
i don't floor it. to me its a luxury car, not a sports car.
Old 12-26-05, 04:12 PM
Brandicus
Brandicus's Avatar
ive always put premium in my 93, i tried the midgrade once and there was a noticible change in the smoothness of the car. I think its wiser to follow the manfacturers reccomendations
Old 12-26-05, 07:47 PM
denverdog
denverdog's Avatar
premium here is 91.
Old 12-27-05, 12:01 AM
KilaWombat
KilaWombat's Avatar
I also have a 93 ls400 and ever since i've had it, i've put premium (91). The manual states: "premium unleaded gasoline with a research octane no. 96 (octane rating 91) or higher. gasolines with an octane numberas low as 91 may be used if premium unleaded gasoline cannot be obtained." I'm in California and premium is 91.
Old 12-27-05, 09:00 AM
Macc
Macc's Avatar
Will 91 ethanol work OK?
Old 12-29-05, 07:28 PM
FD5
FD5's Avatar
Premium fuel is required for the high compression engine. The higher temp burn reduces carbon build up on the cylinder heads, valve stems, valves and exhaust ports. The way I see it the engineers that build these engines know what they are doing and I will pay the extra $10-15 a month for the premium.
Just my .02 worth
Old 12-29-05, 10:09 PM
PVSLS400
PVSLS400's Avatar
i have found at our altitude with my 93 when i run 85 i get around 320 to a tank i put in 91 and i get around 410 or so. it is a wash at the pump the way i see it
Old 02-05-06, 07:56 PM
BigVIPness
The Green Grundel
BigVIPness's Avatar
Default What kind of gas do you put in your car?
I've been putting in 93 but I read in the paper about putting 89-90 in and the car they used for the example was 1990 LS400. I was wondering what everyoe uses and if 90 is ok to use.
Old 02-05-06, 09:32 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
if the prices for premium go over 270 then im switchin back to regular
its like 265 right now
x.x
Old 02-06-06, 12:15 AM
Caoboy
Caoboy's Avatar
i put in premium. i have to, i dont want to take a chance. do what the book tells yah, and suck it up. ***** the car, coast it whenever you can haha.
Old 02-06-06, 02:55 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
93 only...
Quick Reply: What octane gas do you use? (The Mother thread)
