What octane gas do you use? (The Mother thread)
Old 02-11-06, 06:01 AM
  #46
ychachad
ychachad's Avatar
Exactly my point. As gas prices get more and more expensive, and as they are NOT related to engine performance and gas mileage, the percentage difference in price between 87 and 93 octane gets reduced. 87 octane provides less fueal economy versus 93 octane. Therefore, it is actually more cost-effective (cheaper) to purchase the 93 octane!!!!
Originally Posted by RA40
Bottom line is there is no way to get around the lower performance from the lower octane rated fuels. The electronic pooter fuel management curves alter engine performance if you use a lower rated octane. Get on the gas and see for yourself. If you don't feel the difference with the timing retarded by the sensors, your car is out of tune and has other issues to fix.
I'll put in the gas as recommended by the manufacturer because that is what the engine has been calibrated to run on.
Old 02-11-06, 11:58 AM
  #47
RA40
RA40's Avatar
I think that enough feel that using the less pricey gas is sufficient becuse it allows the to drive the car. In the overall expense, the reduced performance and miles per gallon doesnt work out as a savings. At $.20/gallon difference, it is a minimal savings to try and achieve. This leads to the threads on getting the most MPG possible.
Lats night I paid $2.63 for premium.
Old 02-12-06, 04:07 AM
  #48
ychachad
ychachad's Avatar
Here in Florida, I can buy 91 octane at the Citgo pump, and 93 octane. The 91 is 5 cents cheaper, and is a good alternative, if I end up at Citgo. Otherwise I use straight 93.
Old 02-12-06, 05:57 AM
  #49
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Yes, I noticed that with the newer citigos.
Old 02-12-06, 12:12 PM
  #50
Bigkahuna
Bigkahuna's Avatar
Damn $2.63 is cheap. You guys are lucky, gas is getting more expensive here every week. I think it has gone high as $3.79 a gallon for premium. Still not as bad as Europe or Asia, but still hella expensive if you gotta put 22 gallons to fill your tank
Old 02-15-06, 05:20 AM
  #51
dobber
dobber's Avatar
Seems like one of those things. I do what the manual says. Sometimes I cheat, but when you actually price it out it is not a horrible difference.
Old 02-15-06, 04:18 PM
  #52
KilaWombat
KilaWombat's Avatar
premium only
Old 02-19-06, 04:27 PM
  #53
97LS400
97LS400's Avatar
Default Water Injection is the answer
Add a simple water injection system and you can run regular gas with the same mileage and performance as premium. The w/w reservoir on our LS is so large that I only have to top it off every other fuel fill.
Regular gas in the LS400 = retarded timing and sluggish acceleration. Won't hurt anything but the car will be significantly less responsive.
Water injection + regular gas = octane equivalency very close to premium gas. The car responds just as it would with premium fuel.
Water injection + premium = extra fun. The engine management system gives you max-timing advance and you can clearly feel the difference in acceleration.
Water injection also leaves the sparkplugs (I use NGK iridium) looking like new.
Dinocards (10-19-19)
Old 03-08-06, 06:17 AM
  #54
quedawg
quedawg's Avatar
Mike I just bought a Lexus the same color scheme. What all have you done.
Old 03-08-06, 03:06 PM
  #55
berzerkled
berzerkled's Avatar
Originally Posted by BACKNBLACK
if you are short in the cash dept. try this. STP octain boost or any high octain booster gas additive. I go to walmart so i buy the three pack and add them periodically.
I cant allways fill my tank but when I do then I figure Im saving at least 15 to 20 $ on at least a 40 $ tank fill. am I the only one that does this? secondly I only notice a difference in the station to station gas like for instance... the A-plus or Surf gas opposed to the Exxon or Mobil.
Thats just my way of thinking what do you think?
Lol when they say it contains 1 octane point, it's really .1..
Those things do nothing and are just a rip off that unknowing ppl buy.
Old 03-21-06, 10:45 AM
  #56
DavidinCT
DavidinCT's Avatar
I have owned my 1996 LS400 for about 5 almost 6 years, only have put in 91 octance or above. Never a problem, great, smooth running car.
Old 03-21-06, 01:41 PM
  #57
sirtiger
sirtiger's Avatar
93 only. there is no substitution
Old 03-22-06, 12:35 PM
  #58
V8_Fan
V8_Fan's Avatar
chevron 91, 'cause I can't get 93 (any brand) here in AZ. The 20 cent difference is minimal. Performance (have a LX) is noticeably better w/ 91 over 87. Can't say about fuel economy yet since I'm only on my second tank. But higher resistance to detonation means the valves can allow in more air for a higher compression ratio (= more power per engine cycle?). Going uphill, it's definitely noticeable. Car just starts and climbs effortlessly w/ 91, but struggles on 87 (ie, no faster off the line than my 86 4runner w/ 116 hp 4-cyl w/ modified exhaust/cam, advanced timing, 250 lbs of body armor, lift). It doesn't ping on 87, but power is very lacking.The way I look at it, if one can afford to drive such an expensive car, one shouldn't worry about a few bucks extra for a tank of premium!
Old 03-22-06, 01:54 PM
  #59
ajmcd64
ajmcd64's Avatar
Nothing but Shell 93 since I bought my 95 LS 400 six weeks ago. Previous original owner has followed factory maintenance (by dealer only) since new and used only 91 or 93 and car runs flawlessly. Not taking any chances. If it's worked for 11 years and 70k, why change now.
Old 05-08-06, 01:20 AM
  #60
99LS400BLK
99LS400BLK's Avatar
Default TYPE oF GAS?
i was just wondering what type of gas all of you guys use? is it necessary to fill it with supreme? since gas prices are so high, i was wondering if woudl be harmful at all to put plus or regular in the car
Quick Reply: What octane gas do you use? (The Mother thread)
