lexus remote key,battery replacement
Old 08-17-01, 11:59 AM
TypeSC300
TypeSC300's Avatar
can anyone tell me the lexus stock number for the lexus oem remote key BATTERY,my battery on the key is dead and i need to replace it im trying to find a battery for it can anyone help me...
Old 08-17-01, 12:46 PM
TonyN
TonyN's Avatar
just call up the parts deparment and ask for the number, but dont' buy it there. Go to radio shack and such.. I got mine for 2+change, inistead of the $15 lexus wanted.
toiny
Old 08-17-01, 12:47 PM
TonyN
TonyN's Avatar
or bring your old battery to the place, they can usually match it up for you.
Old 08-17-01, 01:05 PM
captclam
captclam's Avatar
Lightbulb Walmart Battery Stand is the answer...
Very simple, take the battery out and go to the WalMart battery stand. Energizer and Duracell both make the same battery for it. $1.65. Just look at the size and voltage. I did mine 3 weeks ago and it still is working great. Let me know if your battery does not have the voltage or number on it and and I give you my exact Energizer part number...
Kirk
93' SC400
Old 08-17-01, 01:12 PM
TypeSC300
TypeSC300's Avatar
the problem i have is that i dont have a battrery in it ,,it never had one do you guys have a voltage number or size number from radio shack or wal mart
Old 08-17-01, 02:43 PM
TonyN
TonyN's Avatar
mine is a 3Volts, if i remeber right its CR-16 or something.. dont' really recall, but i know it's a 3 volts..
hope it helps.
tony
Old 08-17-01, 03:38 PM
Taka
Taka's Avatar
I just opened up my key and it says Panasonic, 3v, BR 1216
(somehow my keyless entry, side mirror, power lock etc...not working)
Old 08-20-01, 07:07 AM
VQT
VQT's Avatar
How do you open the key to take the battery out? I took the screw off, tried to pry it open but it wouldn't pop off, didn't want to break it.
Is there a trick to this?
Old 08-20-01, 08:47 AM
captclam
captclam's Avatar
Wink Everything you ever wanted to know...
(first let me say, Taka... reboot your car! It will work!! Take the negative battery terminal off for 10 seconds and replace it. your trunk release doesn't work either... been there, fixed that!!)
On the battery replacement problem, here ya' go....
Take out the screw... (duh!)
Then while slightly prying the lid up next to the button, slide a small flat head screwdriver tip into the slot you just created... do it just on the other side of the key post. Then gently slide, do not pry, the screwdriver tip around in the crack till you reach the top of the key. It will pop right open.
The lid attaches via the screw and a flap at the very top on the bottom side of the opening for the key fob. I wish I had my digital camera here at work I would post a picture.
The battery is a 3 volt battery. Any 3 volt of the same size will work. It is a 1216 battery. Energizer CR1215 is what I am currently using. Make certain that when you take out or replace the battery you be careful not to break off the small metal clip that grips the side of the battery. You should slid the battery in and out on the opposite side of this clip. Make sure when you install the new battery, you slid it under that clip.
Well there you have it, more information than you ever wanted to know, in boring, painstaking detail!!
Kirk Davis
gotta' love a Lexus!!
(did I mention my wife's name is Alexis??)
Old 08-20-01, 10:36 AM
VQT
VQT's Avatar
Default Re: Everything you ever wanted to know...
Originally posted by captclam
[B
Kirk Davis
(did I mention my wife's name is Alexis??) [/B]
This is exactly what I needed to know 'Then gently slide, do not pry, the screwdriver tip around in the crack till you reach the top of the key. It will pop right open'
Thank You Kirk.
VQT 93 SC400
Old 11-28-13, 10:24 AM
LorenzoE
LorenzoE's Avatar
would disconnecting the battery mess up anything?
Old 11-28-13, 10:54 AM
- V -
- V -'s Avatar
when my remote battery died i just took it to the dealership and they replaced it for free and gave me a second one for my spare key.
mild_se7en
CL of Hawaii
10-01-15 11:52 PM
goya
11-03-14 04:54 AM
puff
08-30-10 08:47 PM
PortAh
RX - 1st Gen (1999-2003)
08-05-03 09:59 AM
neagan
06-10-03 12:53 PM
Quick Reply: lexus remote key,battery replacement
