GS - 1st Gen (1993-1997) Discussion about the first generation GS300
high idle problem
Old 05-25-06, 11:21 PM
YaYAReAGs3
YaYAReAGs3's Avatar
Exclamation high idle problem
hey whats up everybody
M car is have some idle isues..I checked the tps sensor it checked out fine..It idles at 1,5oo RPM while in park and a 1000 RPM in gear .IT doesnt make a deffrence in rpm if te engine is warm or cold..what can it be throw me some ideas on what I can check..thanks for your help
Old 05-26-06, 10:46 AM
Kaiser
Kaiser's Avatar
Turn down the idle screw. Check to see that the plate is fully closing in the tb.
Old 05-26-06, 02:46 PM
YaYAReAGs3
YaYAReAGs3's Avatar
thank you ill check on that..is there away to adjust the IAC sensor or to check if its working right?
Old 05-29-06, 09:09 PM
YaYAReAGs3
YaYAReAGs3's Avatar
anybody know what else I an check on?
Old 05-30-06, 08:06 AM
Kaiser
Kaiser's Avatar
Unplug the IAC and see if it keeps running. Turn the screw down till it's just about to stall and then plug the IAC back in.
Old 05-30-06, 10:21 AM
YaYAReAGs3
YaYAReAGs3's Avatar
which screw ??the stop screws?
Old 05-30-06, 10:32 AM
Kaiser
Kaiser's Avatar
The screw on the throttle body that requires an allen wrench and a 8mm open end. Loosen the 8mm and turn the allen. Adjust and retighten the 8mm.
Old 05-30-06, 10:48 AM
YaYAReAGs3
YaYAReAGs3's Avatar
thanks alot you helped me out big time.
Old 05-30-06, 11:26 AM
YaYAReAGs3
YaYAReAGs3's Avatar
Thumbs up
alright just got back and your right now my idle is finally back to normal
Old 05-30-06, 12:13 PM
Kaiser
Kaiser's Avatar
Awesome. Glad to help.
Old 04-14-08, 08:28 PM
aerosmith1
aerosmith1's Avatar
Um,I'm having the same issue (albeit, 1000 rpm in N), but my throttle lever isn't even contacting the throttle stop. I can twist it barely to make it touch, but it snaps back to a millimeter or two above the stop. I've traced it to the vacuum plunger thing on the front of the TB under the black cover (it kicks out, or *assists* the throttle lever when revving it looks like) - it's resting position is keeping the throttle from closing completely. Anyone have any experience with this? It has a vac line going dtraight to the TB, with black plastic spiral wrap on it.
X99es300X
30
08-30-15 04:13 PM
fyremaster
RX - 1st Gen (1999-2003)
12
04-30-12 12:35 AM
sherwoodjb
01-26-11 07:43 PM
lexdud
Performance & Maintenance
13
12-29-09 09:25 AM
SCmist
09-14-03 11:17 PM
Quick Reply: high idle problem
