Highway Grooves Cause Sway
Old 08-06-06, 07:49 PM
LRubio
LRubio's Avatar
Default Highway Grooves Cause Sway
I have an 06 GS300 that slightly sways when driving on concrete highways that have been grooved. Any suggestions on what causes this or how to correct?
Old 08-06-06, 08:09 PM
rominl
exclusive matchup
rominl's Avatar
i wonder if it's tires tracking the grooves on the freeway. happened to my car with the old tires. after changing tired, nothing anymore
Old 08-06-06, 09:42 PM
LRubio
LRubio's Avatar
What tires did you have and what did you change too?
Old 08-06-06, 10:11 PM
rominl
exclusive matchup
rominl's Avatar
i believe that was yoko avs sport. all tires i had after that (so3, perelli pzero nero, michelin pilot sport a/s, dunlop leman 702) they are all good
keep in mind this is on my 98 gs400 with 19" or 20" wheels.
Old 08-08-06, 08:07 PM
LRubio
LRubio's Avatar
I have Michelin Pilots have tried to adjust PSI, had alignment. Still get fishtail like shimmy on grooved freeways. Any other thoughts?
Old 08-09-06, 12:41 AM
rominl
exclusive matchup
rominl's Avatar
which michelin pilots though, they have a lot of different models. not sure about others, since i have only owned the a/s myself
Old 08-09-06, 07:15 AM
LRubio
LRubio's Avatar
I have the Michelin Sport. Do you think that could be the problem?
Old 08-09-06, 08:06 AM
IS0LD0UT
IS0LD0UT's Avatar
When I was running the S03's on stock wheels, I noticed the same thing. Maybe because they were a really square tire? But after I got the 19s with Toyo T1R have not noticed it since, although I have new suspension also.
Old 08-09-06, 09:30 AM
rominl
exclusive matchup
rominl's Avatar
http://www.michelinman.com/catalog/sports-car/10.html
pilot sport still has more variance. like i said i have the a/s and i am fine, can't really comment on the rest though
Old 08-14-06, 08:53 PM
LRubio
LRubio's Avatar
They are PS2. I'm talked with the tire shop and they're going to trade for the A/S. Can't be worse, this car is moving side to side like a pin ball machine.
Old 08-14-06, 09:49 PM
rominl
exclusive matchup
rominl's Avatar
ah interesting. which part of cali are you in, i wonder if i can try out those roads some time as well. hopefully the a/s will fix your problem!
Old 08-17-06, 08:51 PM
LRubio
LRubio's Avatar
America's Tires installed the Michellin Sport A/S today and they are awesome! Thanks for the suggestion. The Southern California freeways that caused the swerving are the I-10 between the I-15 and 605 also the 210 Freeway from Rancho Cucumonga to Arcadia both directions. But the A/S tires stopped the swerving.
Old 08-18-06, 01:04 AM
rominl
exclusive matchup
rominl's Avatar
i am glad that the new tires help
nothing is better than the car driving nice huh
Old 08-18-06, 05:00 AM
LRubio
LRubio's Avatar
You're awesome rominl! Thanks again.
ciscokid
RC - 1st Gen (2015-present)
23
08-01-19 11:43 AM
15RC350F
12-13-17 09:29 AM
Defratos
IS F (2008-2014)
13
04-29-15 03:19 PM
iceache925
04-08-15 05:02 AM
Quick Reply: Highway Grooves Cause Sway
