How many people have non working factory keyless entry?
Old 09-19-06, 10:22 AM
  #46
JohnEd
JohnEd's Avatar
Default Range
OLT,
Great post! Old tech axiom..."a good visual is worth a hundred tests". I would go one further and get the cold solder joints with a "blanket resolder instruction".
I have two remote keys and they both work if they are inches from the door. I think you have solved my problem and I thought that was the way they operated. My problem is that one key frame was cracked and the button fell out last week. Just my luck.
ANYBODY HAVE AN EXTRA KEY THEY WOULD PART WITH ?
Thank you OLT
John
Old 09-19-06, 10:24 AM
  #47
revlis240
revlis240's Avatar
no need for an extra key, mine cracked and the button fell out as well..here is the solution
1) use glue to put the broken piece back on (this works well)
2) use a button from an old nokia 5000 series phone to replace the lost button. its the perfect size/shape/form for the hole
Abe
Old 09-19-06, 11:43 AM
  #48
AME_VIP
AME_VIP's Avatar
Originally Posted by revlis240
DUDE!!!!
my key used to work only when right next to the car. i opened the key up and soldered the antenna and BAM!! works from far now!!
Abe
oohh nice! Can you provide some more detail on what I need to solder?
Old 09-19-06, 11:50 AM
  #49
np20412
np20412's Avatar
There's a pic of it on page 1 or 2, inside the key..
OLT, My connection in the key seems ok yet I can't do anything to get a tone out of the stereo. I did change the battery, and the keyless entry ON switch under the steering wheel is ON. What is my next step, or do you not know? I will get a pic of the inside of my key later on tonight, maybe you can tell me if it does need to be soldered, but from looking at mine and comparing it to the pic of yours, it did not look like it was broken at all.
Old 09-19-06, 12:00 PM
  #50
AME_VIP
AME_VIP's Avatar
sorry about that I just checked out the first page. Thanks for the help.
Old 09-19-06, 03:24 PM
  #51
O. L. T.
Keeper of the light
O. L. T.'s Avatar
dead transmitter FTL.
Old 09-19-06, 03:33 PM
  #52
np20412
np20412's Avatar
DAMN.
I'll assume that the cost to replace the transmitter and reprogam is off the charts and completely not worth it huh
Old 09-20-06, 08:27 AM
  #53
goldencan
goldencan's Avatar
Originally Posted by aftv
Mine is not working at all even with a new battery...but I haven't tried the radio thing..didn't know about that..what kind of reaction are you supposed to get with the radio..?
Thanks
I tried the radio at 94.9 but it's a music station
Old 09-20-06, 01:04 PM
  #54
np20412
np20412's Avatar
same here, but if its gonna make a tone it will make it over the music anyway
Old 09-23-06, 07:49 PM
  #55
udfxrookie
udfxrookie's Avatar
I'm in the same boat, I think my transmitter is completely gone. If I get a new key off of e-bay or one that works how do I reprogram that key. Do I do the "remove the rear seat" keyless box DIY tactics as explained earlier? Will that do the trick?
Old 09-23-06, 07:54 PM
  #56
O. L. T.
Keeper of the light
O. L. T.'s Avatar
The receiver is behind the seat, which has nothing to do with the transmitter problem. It's one or the other.
I think Lexus will have to reprogram.
Old 09-23-06, 11:50 PM
  #57
JspecSC3
JspecSC3's Avatar
Mine is currently not working. I kind of broke the remote. It still works but only when I really press hard on the button. Other than that everything is all loose.
Old 09-24-06, 08:19 PM
  #58
udfxrookie
udfxrookie's Avatar
How does Lexus reprogram the key. They told me it would only be like $30, for the time/labor which is really nothing but I was curious on what they actually do.
Old 09-25-06, 10:04 AM
  #59
joel(PA)
joel(PA)'s Avatar
my key doesnt unlock the doors.
I got a tone on 94.9, so the key works. One thing i noticed while sitting in the car, when i go to press the door lock button, the doors wont lock, but they will unlock. is that a problem or is there some safety that wont let you lock the doors from the inside when the key is not in?
Also, the rear seat thing. what does that actually test for, broken reciever antenna?
Old 09-25-06, 01:33 PM
  #60
np20412
np20412's Avatar
When you pressed your door lock key, was the key in the ignition? Lexus was smart and didn't want us to lock our keys in the car, so you can't lock the doors while the key is in the ignition.
Quick Reply: How many people have non working factory keyless entry?
