How many people have non working factory keyless entry?
Old 09-26-06, 06:13 AM
  #61
udfxrookie
udfxrookie's Avatar
Ok, after checking out the diagram of the key I resoldered the main point shown and now at 95.1 when I press the button I don't get a tone but it interrupts the radio with silence while pressing the button.... nothing on any other stations... what's that mean? Can I get this key to work again?
Old 09-26-06, 06:23 AM
  #62
joel(PA)
joel(PA)'s Avatar
Originally Posted by NYLexSC
When you pressed your door lock key, was the key in the ignition? Lexus was smart and didn't want us to lock our keys in the car, so you can't lock the doors while the key is in the ignition.
i tried to press the lock button with the key in AND out (both doors shut) and nothing happens. could this cause the keyless not to work? wouldnt it still unlock since that button works? I'd really like to get the keyless working because someone tried to steal the car by screwdrivering the drivers side lock and the key will only work in the passenger side now.
also, what does the rear seat key trick test for? i get a tone on 94.9 and my keyless switch is set to on.
Old 09-26-06, 06:42 AM
  #63
attis
attis's Avatar
Post
My wireless also dead.
When I bought the car it was OK, but later I had to push the button for a long time, or push it several times to open the doors. Now it does not work at all. I changed the battery but nothing happened. I tested the battery with a multimeter (2.9V), I don't know if its okay... Also, I checked the connectors inside the key, and it seems that there is a working circuit in the key when I push the button... Now I'm not sure if the problem is with the key, or with the car.... And, the security alarm starts when I open the door with the key from the driver's side (it seems that the key does not operates the central lock in that door). However, it works OK with the passanger side door.
Attila
Greetings from Hungary!
'93 SC 400
Update: I've tested the key with the radio, and it seems that the key is working fine
Old 09-26-06, 07:31 AM
  #64
Lexatron
Lexatron's Avatar
Originally Posted by revlis240
no need for an extra key, mine cracked and the button fell out as well..here is the solution
2) use a button from an old nokia 5000 series phone to replace the lost button. its the perfect size/shape/form for the hole
Abe
Sweet info!
I have the exact same problem.
Could you post a link to the Nokia 5000 phone/button? I can't seem to find it anywhere.
Old 09-27-06, 03:51 AM
  #65
udfxrookie
udfxrookie's Avatar
I get the tone on 95.1 and tried putting the key in the antenna of the control modle and pressing the button and nothing happens... what now?
Old 10-02-06, 05:43 AM
  #66
udfxrookie
udfxrookie's Avatar
bump... any ideas on what to do now?
Old 10-06-06, 04:27 PM
  #67
Lexatron
Lexatron's Avatar
Bump*....................................................
Old 10-06-06, 08:30 PM
  #68
O. L. T.
Keeper of the light
O. L. T.'s Avatar
buy a new control module, or blame the prom IN the control module.
Old 10-07-06, 09:17 AM
  #69
mattsmall
Registered User
mattsmall's Avatar
add me to the list iv tryed replacing the battery ect, but still nothing works.
Old 10-08-06, 09:17 AM
  #70
Blu92SC4
Blu92SC4's Avatar
Hey OLT,
Thanks for putting up this thread. My keyless entry has been workin but I'd have to be a couple feet from the car. Usually close to behind the drivers seat. Well, I tried out the radio thing and voilla!...My key can now work from up to ~40 ft...which is alot better than 2-4 ft.
Old 11-15-06, 08:24 AM
  #71
fooldall
fooldall's Avatar
OK, I did the radio test as well. I heard tone. So, at this point, I need to dig into the back seat, disconnect the grey wire from the keyless remote box and press the button again? Does this reset the system? Not sure I understand the directions...
Thanks for any help guys....
Old 11-15-06, 09:27 AM
  #72
sc250tt
sc250tt's Avatar
if i remove my factory radio can i still fix my alarm?
Old 11-15-06, 06:36 PM
  #73
Supra Dr
Moving SC Threads
Supra Dr's Avatar
Post up a pic if you go digging, I'm too lazy to try it. Unless it's not that
big of a deal to pull the panel.
Old 11-15-06, 07:19 PM
  #74
O. L. T.
Keeper of the light
O. L. T.'s Avatar
yes pull the back seat and check it.
Old 11-16-06, 07:48 AM
  #75
stonewis
stonewis's Avatar
Mine's busted!
Quick Reply: How many people have non working factory keyless entry?
