Changing brake lights in my GS300
Old 09-10-06, 10:51 AM
karamba
karamba's Avatar
Default Changing brake lights in my GS300
I just got my 2003 GS300, and im already having troubles with the brake lights. The right inner bake light went out, but i just popped the back off and replaced the bulb.
I need help though, can anyone help me change my outer right brake light? Im confused as to how i should go about repalcing the bulb myself.
Old 09-10-06, 12:13 PM
JeffTsai
JeffTsai's Avatar
I think you have to remove the brake light housing. There are 4 hidden nuts/screws. Now go hunt for them
Haha, ok I'll give you a hint. Look in the trunk there should be two round caps. pop them off and there will be a 10mm nut in there you remove. Then around the black plastic part of the taillight there will be plastic caps. Pop those out and there will be screws under there as well. Pull the housing straight out and you should be able to replace the bulb.
Good luck!
Old 09-10-06, 01:15 PM
karamba
karamba's Avatar
Thank you very much, i found the caps and am currently in the process of replacing the bulb.
Old 06-19-07, 12:48 PM
minla007
minla007's Avatar
my left 'inner' trunk brake light is out.
what type of bulb do i need? and how do i replace it? please advise. thanks.
AlDavison
08-04-11 06:53 PM
user 528962307
Lighting
11-16-09 10:43 PM
UberNoob
06-01-09 09:00 AM
mzeitlin
RX - 1st Gen (1999-2003)
11-24-07 05:15 AM
gs3_4me
Maintenance
07-06-04 06:01 PM
Quick Reply: Changing brake lights in my GS300
