Replace SC430 Antenna
Old 09-13-06, 04:47 PM
hlovepenn
hlovepenn's Avatar
Default Replace SC430 Antenna
My wife's SC430 chewed through its antenna drive cable and I need some suggestions on accessing the motor. I have replaced two antennae on my LS400s, including removing the broken cable from the drum, so I know how to do that, but I'm not sure what I need to remove to access the unit on the SC430. E.g., do I need to remove the right bracket that holds the top clearance sheet mechanism? Any help is appreciated. Thankx for your help!
Old 09-13-06, 07:07 PM
sc430mike
sc430mike's Avatar
Try this thread...
https://www.clublexus.com/forums/sho...unplug+antenna
Old 09-14-06, 01:57 AM
Pearlpower
Pearlpower's Avatar
https://www.clublexus.com/forums/sho...=antenna+sc430
Old 09-14-06, 11:05 AM
sc430mike
sc430mike's Avatar
Default Antenna Issues
Hi guys,
I unplugged my antenna on my 2002 SC430 so that I wouldnt have to see that ugly thing and I was satisfied for a while, but now I am getting bad reception in some spots and I still wish I could add that LMS short antenna that we have seen in previous posts. The short antenna only works on 2003 SC430's that have the non retractable antenna that can simply be screwed off. So... my question to you guys is whether or not I could buy some of the mechanical parts for a 2003 antenna from Lexus and have an audio specialist install the short antenna on my 2002?
I know most of you think that this would be a waste of time and money, but little things like this could make me so much more happy with my ride since I often listen to FM radio.
Thanks for reading this and for any advice/ideas.
-Mike
Old 09-14-06, 11:15 AM
GSXOTIC
GSXOTIC's Avatar
Anyone knows if there is a replacement antenna like the ones on the SL from MB?
Old 06-30-09, 02:02 PM
Monteshere
Monteshere's Avatar
The plastic cable for my antenna broke in the unit. It won't extend to where I can remove it easily. Is there any fairly easy way to remove the entire mast? Do you go throught the wheel well as I don't want to remove any of the top up/down drive mechanism?
-Monte
Old 07-01-09, 08:08 AM
deadeyed
deadeyed's Avatar
this is the SL antenna. not plug & play though.
Old 07-01-09, 03:09 PM
tromly
tromly's Avatar
I too have been searching for a replacement antenna like the SL's, anyone out there see a plug and play on the market??
Old 07-01-09, 03:41 PM
talwang
talwang's Avatar
The oem antenna makes the sc430 look like a remote control car.
you can either unplug it or find some replacement like
Old 07-01-09, 03:45 PM
PhilipMSPT
Cycle Savant
PhilipMSPT's Avatar
That is something that I have been looking for. Just a simple knubbie, instead of a folding metal mast.
Old 07-02-09, 04:51 AM
iolmaster
iolmaster's Avatar
OK I'll bite. Where do we get these?
Old 07-06-09, 02:39 PM
Lapraka
Lapraka's Avatar
Slik! I want one in black please!!!
Old 07-06-09, 04:07 PM
talwang
talwang's Avatar
NOT plug and play as deadeyed has mentioned, it requires some custom work to fit.
Old 07-09-09, 10:21 PM
Peter_Klim
Peter_Klim's Avatar
what about something more stealth like running a wire along the trunk? Wish it was built into the dash window
Old 12-02-15, 01:52 PM
Blackwing
Blackwing's Avatar
What about the rubber one? How hard are they to install and which one should be bought for that project?
Quick Reply: Replace SC430 Antenna
