GS - 1st Gen (1993-1997) Discussion about the first generation GS300
How do you Remove Subwoofer in the Rear Deck?
Old 10-01-06, 04:01 PM
AirForceGS
AirForceGS's Avatar
Default How do you Remove Subwoofer in the Rear Deck?
Just thought before i go in the trying to just pull off the speaker screen that i get some info about removing it. I want to replace it with one of the many 12" aftermarket speakers i have in my garage. The original Lexus speaker tends to pop at higher volumes. So is there anything i need to know?
Old 10-01-06, 04:24 PM
Abear
Abear's Avatar
It pretty easy to remove, I think there are 4 bolts holding it it. You have to remove the backseat and the pull the whole rear deck cover forward. After that you should be able to see the bolts. Fitting a 12 isnt going to be as easy as you think. You will have to make a new baffle for it, the stock sub is a 10.
Old 10-01-06, 04:35 PM
AirForceGS
AirForceGS's Avatar
I thought it looked like a 10"... Remove the etire backseat?
Are there any diagrams or links for intrustions for this?
Old 10-01-06, 04:42 PM
Abear
Abear's Avatar
Not really. The backseat is 2 pieces, the seat, and then the back. Just pull up on the bottom of the seat and it should pop out. Then there are 4 10 or 12mm bolts holding the back in place. After that, like I said, that rear deck cover slides forward, but I think there are some pins you have to remove first.
Old 10-02-06, 09:06 PM
JPGS300
JPGS300's Avatar
I have a 12" sub in the back of mine I replaced my stock sub for a 12" kicker free air sub, and if fit with no problems, kinda weak tho the factory amp doesnt push it as well as the stock one.
Old 10-03-06, 08:17 AM
Kaiser
Kaiser's Avatar
The factory amp is what sucks. I replaced the amp with a Soundstream edge 5 channel and got an eclipse head unit with everything I needed to wire it up for $460 shipped. www.millionbuy.com is where I got the equiptment. Their shipping speed is amazing.
Old 10-03-06, 09:13 AM
El Captain
El Captain's Avatar
Can you guys post a pic of the rear deck sub?
Old 10-04-06, 08:14 PM
okiaristo
okiaristo's Avatar
i just did a quick post to explain this. here is is.. a search is always helpful before posting
https://www.clublexus.com/forums/sho...d.php?t=241082
oh and the screen is attached pretty securely so i wouldn't try to just pull it off. 8 pins i believe
etronics.com has yet to do me wrong...
Old 10-18-06, 07:28 PM
Lexus Boy
Lexus Boy's Avatar
great write up did the same with my amps
[/IMG]
Old 10-25-07, 03:33 AM
Sleepy562
Sleepy562's Avatar
nice. good looking out!!!
Moondog
10-02-14 07:20 AM
james123
11-30-09 11:07 AM
marcuse
02-04-09 11:53 AM
lexodude
06-19-06 01:38 AM
Mr Patel
02-07-06 06:04 AM
Quick Reply: How do you Remove Subwoofer in the Rear Deck?
