Left Front Speaker Only Works Occasionally
Old 11-27-07, 08:12 AM
nicknace
nicknace's Avatar
Same exact problem in my 98 GS 400 with the NAK. I changed the speakers twice, took them apart and replaced the innards, and replaced the amp (with another used one). No fix.
Old 11-27-07, 09:04 AM
skaiyun
skaiyun's Avatar
haha i don't have anything useful to say. but it happens to me too! i just turn the volume up and it goes away
Old 11-27-07, 10:44 AM
Saiji
Saiji's Avatar
same problem here also. 2002 gs430. Only my left speaker works now.....
Old 11-28-07, 11:30 AM
nicknace
nicknace's Avatar
Do you mean it gets better, or you just care less with the volume up?
Old 11-28-07, 11:50 AM
DJ TANTRA
DJ TANTRA's Avatar
I think it might be the wires that are runnign to the speakers...
as sum1 mentioned they might be shorting somewhere...splice the wire from near the amp...and replace it...
see if it goes away!
it hasnt happened on my 01 gs premium.
Old 11-29-07, 11:12 AM
GSspeed
GSspeed's Avatar
mine is doing the same aswell, but mine is the tweeter that is going off and on, and the sound does not sound as crisp as the right side (drivers side tweet is bad)
it sounds like im going deff in my left ear cause my right tweeter is now louder than my left, hahahaha,
I guess some new speakers are soon to be coming, but the question is what kind since i have the NAK system...
Old 12-01-07, 08:20 AM
nicknace
nicknace's Avatar
I have spare stock tweeters to spare. PM me your address and I'll send you one free of charge if you want.
Old 04-12-08, 06:10 PM
Chumacher
Chumacher's Avatar
my left speaker and tweeter has the same problem. it's probably the amp or the wiring since it's affecting them both at the same time.
Old 06-19-08, 10:58 AM
RX729
RX729's Avatar
same thing with my front left speaker... I usually kick it with my foot and it turns back on...
Old 06-19-08, 11:10 AM
r00kie
r00kie's Avatar
2000 gs400...have same problem on my passenger front speaker. Adjusting the volume seems to work for now. It comes and goes.
Old 06-19-08, 11:14 AM
TruPlaya26
TruPlaya26's Avatar
Whenever I hear mine starting to go out I punch it (not hard) and it goes back to normal ...
Old 06-19-08, 05:42 PM
gsCrazy
gsCrazy's Avatar
same problem here with my driver side front speaker.... and as quite a few guys have mentioned already, turning the volume up and then back down fixes it.
Old 05-09-12, 07:45 PM
Phantom300
Phantom300's Avatar
Going to chime in because my GS400 has the same problem for the driver side speaker. Any clear solutions?
Old 05-10-12, 05:23 AM
RamAirRckt
RamAirRckt's Avatar
Mine does it too. Seems more related to going bad when i have recently put stuff in the trunk. The amp is on the right side in the trunk.
Old 05-10-12, 07:27 AM
neegroy
neegroy's Avatar
most likely the amp.
or if your running stock setup like me with aftermarket subs and speakers and amps, it might be the hi-low converter ( basically it allows the aftermarket stuff to work on your oem base setup ) i changed that out right away as soon as i found the right speaker was going in and out like yours.
Quick Reply: Left Front Speaker Only Works Occasionally
