Replacing the OEM battery in the RX330
Old 06-02-08, 05:39 AM
  #31
Lexmex
Lexmex's Avatar
I have an Optima, but only reason that I bought it was for performance reasons.
At some point I am planning on getting one of these batteries www.brailleauto.com
There are also some other lightweight options like http://www.odysseybatteries.com/
The braille I have seen in person and they are a bit smaller (at the 21 pound version (top end) than a normal OEM battery).
Old 12-13-08, 11:46 AM
  #32
rbnaidu
rbnaidu's Avatar
Default Battery Replacement charges at dealar
Originally Posted by Nept_Mica
Back to the Lexus dealer I went. They installed an Interstate battery manufactured for Lexus. Total cost for the battery with installation was $110.
Last week i went my dealer and was told $220 for replacing the battery for my RX 330 ???????
Checked with Costco - battery available for $70 ( less 9 if old is returned)
Is it good ?? or should I look for Optima ??
- Rbnaidu
Old 12-13-08, 12:53 PM
  #33
tfischer
tfischer's Avatar
220 is too high, but some of that cost was for the labor, I'm sure. I just replaced the battery in my SC and my RX last year, and the RX battery was about 100 and the SC battery was much more, but it was much bigger and heavier. I bought both from the dealer and installed them myself, which takes about 20 minutes each. The dealer will give you a credit when you return the old one, either at the time you buy the battery or later, after you do the switch.
Optima batteries have a good reputation, but they come in only a few sizes, and you need to fiddle with the cables and the connections to make them fit. As for those from autozone and such places, I do not know whether they are comparable to those that the Lexus dealers carry or not. As I recall, Interstate batteries have a good reputation for reliability.
Old 12-13-08, 05:00 PM
  #34
catdaddylo
catdaddylo's Avatar
Interstate makes batteries for a lot of foreign automobiles. The OEM Lexus battery is made by Interstate is what I was told by a Lexus mechanic.
Old 12-13-08, 10:03 PM
  #35
cdnewton
cdnewton's Avatar
Probably depends upon where your RX is made. Our Made in Japan 2004 RX330's battery was made by Panasonic, which by the way, makes an excellent battery.
Old 12-14-08, 04:33 AM
  #36
luxury1
luxury1's Avatar
Good topic! I really need to get on this as I haven't replaced my batter in my '04 Lex. I had one of the first ones out so my battery is pretty old now. No signs of weakness but I definitely don't want to be stranded somewhere.
Old 12-14-08, 04:56 AM
  #37
luxury1
luxury1's Avatar
By the way, does Lexus replace the battery as part of any major services like the 60,000 mile service?
Old 12-14-08, 07:23 AM
  #38
salimshah
salimshah's Avatar
Battery is covered under warranty.
If it goes bad early, then like other warranty items is replaced.
I still recommend sealed batteries as they help eep the engine bay clean. They do cost extra.
Salim
Old 12-14-08, 07:58 AM
  #39
tfischer
tfischer's Avatar
"By the way, does Lexus replace the battery as part of any major services like the 60,000 mile service?"
Wouldn't that be nice? But really, if your battery is still working at 60,000 miles, it's time to buy a new one anyway before it dies on you in the mall parking lot. I did that when the original battery had gone 45,000 miles and 5 years, and I'm glad I did.
Last edited by tfischer; 12-14-08 at 07:59 AM. Reason: Deleted references to that sweet federal bailout money.
Old 12-14-08, 08:01 AM
  #40
Lexmex
Lexmex's Avatar
Mine was on the fritz in my RX300 many years ago and Lexus did replace it under warranty.
Old 12-20-08, 03:06 PM
  #41
luxury1
luxury1's Avatar
I just replaced the battery and boy was it easy. I am not the type of person that knows his way under the hood but it was absolutely simple. I followed the below directional video and had it done in 10 minutes.
I bought the battery from the Lexus parts department for $100.
http://www.ehow.com/video_512_replace-car-battery.html
Now I can rest easy!
Old 12-30-08, 12:37 PM
  #42
My0gr81
My0gr81's Avatar
Costco lists the replacement as a Group 24F and suggest a Group 35 (or Costco's number 8) battery. The Group 34/78 (Costco's number 1) is higher CC/CCA, same height as the Group 35 with the spacer on but it is a little longer. If anyone got a Costco battery, can you post the type you got?
Thanks
Last edited by My0gr81; 01-02-09 at 03:51 PM. Reason: Changed Costco's replacement number for the 34/78
Old 01-02-09, 03:50 PM
  #43
My0gr81
My0gr81's Avatar
Turns out the original was an ACDelco Group 24F. Went to couple of the major places in the GTA (Canada) and most had the battery with a 2 years replacement and 60 months pro-rate. Wal-Mart had the Optima red top (34-78) for about double the price of the regular 24F. Group 35 battery is an alternative as it is the same height, width but about 2" shorter. Group 35 also has higher CCA (640A vs 540A), higher CA (800A vs 600A), and longer reserve capacity (110min vs 90). I ended up buying the Costco Group 35 replacement with 36 months replacement and 72 months pro-rate warranty for cheaper than the others major outlets. The Costco replacement code is Type 8.
Old 01-03-09, 02:16 PM
  #44
mandyfig
mandyfig's Avatar
Post a pic, if you can, we like to see the install. I have been eyeing the Costco battery in case I will need one. All my other cars have the Costco batteries, they are made by Johnson Controls. 3 years full replacement, they are great, then it is pro-rated. Can not beat it. The battery price have gone up at least $5 the last few months.
Old 01-03-09, 05:39 PM
  #45
My0gr81
My0gr81's Avatar
I replaced the battery because I had to boost the RX when I left the keys in the ignition while shoveling the driveway. That is less than 1/2 Hr. That same day, I had to boost it again, after a 2 hours highway drive, parked in a parking garage because I left a charger plugged in the cigarette lighter plug. It sure looked like that battery wasn't holding a charge anymore. $85 is cheap insurance instead of being stranded somewhere in the winter waiting for a boost or a tow truck.
There is already a link to a video that goes through the battery replacement process on this thread. It is pretty much bang on. As far as the pics of the battery, it is the same as all the other batteries, except it has Kirkland label on it.
Here is a link with specs on the different BCI Group Numbers for batteries:
http://www.batteryweb.com/bci.cfm
Here is a link to really good information in FAQ style about automotive batteries:
http://www.bdbatteries.com/autosizing3.php
Quick Reply: Replacing the OEM battery in the RX330
