What is the trip reset button?
Old 03-11-07, 12:45 PM
ar4605
ar4605's Avatar
Default What is the trip reset button?
1. turn the key to the ON position which means pressing the start button twice on the new IS since it doesn't has the key, foot off the brake
2. Press the trip reset button couple of times until the ODO is displayed (not trip A or B)
3. turn the ignition to the LOCK (OFF) position
4. unbuckle the driver's seatbelt if it was buckled.
5. turn the key to the ON position again press the start button twice. when the dash lights comes on, press and hold the trip reset button and count a slow 12 seconds. (editor's note, hold it more like 30 sec)
6. while still holding the trip reset button, buckle the driver's side seatbelt.
7.and the odometer display should read "b ON" or "b OFF". toggle the beep OFF with the trip reset.
8. the process should be completed when you unbuckle or turn the key off.
Old 03-11-07, 12:50 PM
Irishman06
Irishman06's Avatar
Its the button next to the odometer you press to reset the trip-meter (the a and b things)
Old 03-11-07, 01:03 PM
ar4605
ar4605's Avatar
Can you explain this? Where is the toggle button?
Old 03-11-07, 02:17 PM
Irishman06
Irishman06's Avatar
You hit the trip reset button to switch from "on" to "off" and back again.
Old 03-11-07, 02:31 PM
15951's Avatar
This is priceless.
Old 03-11-07, 02:38 PM
duckduck
duckduck's Avatar
Originally Posted by 15951
This is priceless.
funny how we take some knowledge for granted now. It reminds me of the simpson's episode.
"Press any key...where's the any key?"
Old 03-11-07, 02:40 PM
NGG
NGG's Avatar
Huh!!. All this just to reset the trip meter. Ain't electronics priceless. Perfect example of how to complicate a perfectly designed and simple manual process that has worked fo years on older cars and current basic models. See BMW "I-Drive" for another useless example....all in the interest in being different to seperate us from hard earned $$$$!
Old 03-11-07, 02:58 PM
duckduck
duckduck's Avatar
...that's not to reset the trip meter. This is to disable the seat belt warning light.
If you want to reset the trip meter, go to either Trip A or Trip B...and hold the trip button.
Old 03-11-07, 05:34 PM
15951's Avatar
Yeah...you should see the pedal dance Lexus has us do just to open the sunroof.
Doesn't anyone read the manual anymore?
Old 03-11-07, 06:20 PM
Irishman06
Irishman06's Avatar
That's nothing. I had to change my blinker fluid this weekend, and to get to it, I had to take apart the entire camber compensator assembly, remove the anti-vibration potentiometers, not to mention the johnson rod and all the usual goodies. It took up my entire Saturday to do a 5 minute job, because I had to go buy metric screwdrivers to do the camber compensator.
Old 03-12-07, 12:15 AM
cc16ue
cc16ue's Avatar
up up down down left right left right select start
Old 03-12-07, 12:35 AM
sirkfc
sirkfc's Avatar
that's not right.
it's u u d d l r l r B A select start.
bonus points for whoever can identify this code burned into my memory...
007 373 5963
Old 03-12-07, 01:32 AM
nyquest
nyquest's Avatar
Originally Posted by sirkfc
that's not right.
007 373 5963
CONTRA for extra lives
Old 03-12-07, 09:00 AM
sirkfc
sirkfc's Avatar
well, the Contra one was easy. I meant the 007 373 5963. It's a code for another popular game... I think only people in the 27 - 32 age range will think it's familiar...
Old 03-12-07, 09:53 AM
Shoyuu
Shoyuu's Avatar
that's not right.
007 373 5963
Mike Tyson baby!
Quick Reply: What is the trip reset button?
