Door Lock Acutuators DIY ???
Old 02-20-14, 08:47 PM
  #1051
islexusred
islexusred's Avatar
Originally Posted by Damen01
Hey guys, I just bought a 03 gs430 last week,and i believe I already have an issue with the actuator on the driver side door.it still locks,but only manually..do I need to get it replaced?
Yeah! But only the motor inside the actuator. You can get all 4 of them for about $20 on eBay! Also I'd recommend you to replace all 4 motor since you're at it, the other 3 will soon follow.
Old 02-20-14, 09:08 PM
  #1052
TTurboPimp
TTurboPimp's Avatar
I just replaced the two fronts in my LS430, easy to do if you any mechanical skills, and cheap
Old 02-22-14, 07:00 AM
  #1053
Damen01
Damen01's Avatar
thanks for the info
Old 02-22-14, 07:59 AM
  #1054
marty99
marty99's Avatar
Just bought a couple of motors. Does the post need to be shaved flat, or will my original gear just slip on?
Thanks,
Marty from muggy S. Florida
Old 02-22-14, 12:00 PM
  #1055
fracmann1
fracmann1's Avatar
i have the same problem on pass back
Old 02-22-14, 10:45 PM
  #1056
islexusred
islexusred's Avatar
Thanks,
u need this http://goo.gl/j6Vcbl to pull the gear from the old motor and place it on the new motor. just be careful not to break the plastic casing when getting to the motor. Just be patient and take your time. it took me close to 20 minutes to crack on actuator open
Old 02-26-14, 03:19 PM
  #1057
bogeyman
bogeyman's Avatar
Big thanks to the OP and all posters for this DIY.
After going through this whole thread I have a pretty good idea of what to do. The only question I have is regarding the worm gear inside the actuator. It reminds me alot of the worm gear used in a garage door opener, which is supposed to be lubed generously with white Lithium grease when replaced.
Should this worm gear be lubed with Lithium grease when changing the motor and resealing the actuator?
Thanks.
Old 02-26-14, 09:27 PM
  #1058
islexusred
islexusred's Avatar
Thanks.
When i did mine they were still pretty lubbed! I just left them as they were.. But it wont hurt to put some on there while you're at it.
Old 06-01-14, 01:01 PM
  #1059
Diamond080
Diamond080's Avatar
Just completed the job on our RX300 2001. Had a real hard time with the pink clip mounting to the silver rod. Quick tip make sure the silver rod is on the opposite side of the plastic from the gold rod makes a big difference. Also don't forget the screw under the arm rest caused us to make a small crack in the door panel.
Good luck
Dan
2001 Lexus RX 300
2008 Chevy Tahoe
Old 07-06-14, 08:54 PM
  #1060
larryhirs
larryhirs's Avatar
I did a rear door on my 2000 in 2010. Posted on page 34. Worked great for 4 years. Now my kid is using this care for 1 or 2 more years and the locks are not workinbg. I can't believe how long this thread is!
All the locks actuate-- try to lock then unlock a few seconds later. I think just do all four now based on trying the inside auto lock. I referred to a motor someone mis-posted in skimming this thread again that was wrong and doesn't fit when I did the driver's door yesterday. Fortunately had one motor from the repair 4 years ago. The problem is I had removed the coupler with the gear puller on ebay, put it on the wrong motor before realizing it was incorrect motor, removed it and now the coupling is not snug on a new motor.
Can anyone suggest what glue or epoxy might best work to hold the coupling? It taps down but is clearly not snug enough. I see on ebay you can by the actuator motor casing assembly only now for about $25 and maybe that is the solution for that door?
Old 07-14-14, 01:01 PM
  #1061
zzr600
zzr600's Avatar
Try this.
Part 1
Part 2
Hope it helps
Old 07-29-14, 03:47 PM
  #1062
slonis888
slonis888's Avatar
Default mr
Originally Posted by TRD911
BTW I love pictures cant you tell. And another,
BP
MAN u have done such a GREAT job with the pictures... I have ordered a couple motors for my 2010 Prius and I think I'll try to do the same thing you did as well as you... a great example bud.
Old 08-04-14, 06:50 AM
  #1063
larryhirs
larryhirs's Avatar
Thanks again to all who contributed. I did this to one rear door 4 years ago on my 01 GS300. Then last month it seemed like all the doors were going. The locks using the fob or door switch would try locking then unlock, leaving some doors locked with varying results and weird things happing withe the arm getting set when doors were unlocked. Ended up doing all four. Much easier after you've done a couple. I did screw up one actuator motor spindle and found on ebay you could buy a new one specific to particular door for $26.
Old 08-04-14, 09:35 AM
  #1064
tiger4life
tiger4life's Avatar
I just installed one of the Chinese actuators off of ebay on saturday. It's working fine so far. I guess I'll see how long it last. I still have an OEM one that I need to install in one of the rear doors.
Old 08-06-14, 11:30 PM
  #1065
Cman333
Cman333's Avatar
I wanna thank the OP for making this thread. Made life a little easier.
I just tackled this job but I ordered the whole lock assembly from Toyota. I didn't go through all 70+ pages of the thread but figured I should mention to who ever is planning on doing this DOES NOT need to remove the window to get the driver door latch assembly out.
Basically do exactly as the OP has said except instead of removing the whole window + regulator all you need to do is loosen the one bottom left window track bolt. You can simply just wiggle the track out of your way to get the latch assembly out.
You still need to remove the outter door handle. 3 bolts, remove the two door rods and voila....it's out.
Had it in and out in about 1.5 hours. Factoring in a smoke break and having someone stop by for 10 mins.
Thanks again OP
Quick Reply: Door Lock Acutuators DIY ???
