Cross referencing lexus/Toyota part #s
Old 07-09-07, 11:00 AM
bkim
bkim's Avatar
Default Cross referencing lexus/Toyota part #s
Hi. I have a 99 AWD Rx300 and I need to get some parts and would like to get them at my local Toyota dealer because it is close and I can get a really good deal from them. I have gone in and talked to them, but they can't or won't cross reference with Lexus part #s. Is there a website or database where I can do this? I'm looking for left and right front strut mounts with bearings and transmission filter & gasket. Any help would be appreciated.
Thanks
Old 07-09-07, 11:58 AM
L0c0
L0c0's Avatar
stay tuned... I'm checking Alldata for the part#'s
Old 07-09-07, 12:03 PM
L0c0
L0c0's Avatar
1999 Lexus Truck RX 300 4WD V6-3.0L (1MZ-FE)
Vehicle Level Steering and Suspension Suspension Strut Mount Parts Information
Parts Information
Part OEM Part Price
Strut Mount
Front Suspension
12 - Right 4860333021 $72.71
Contact dealer for most current part and price information.
12 - Left 4860933121 $72.71
Rear Suspension
11 - Right 4875048010 $113.15
11 - Left 4876048010 $113.15
Vehicle Level Transmission and Drivetrain Automatic Transmission/Transaxle Transmission Gasket Kit Parts Information
Parts Information
Part OEM Part Price
Transmission Gasket Kit 0435121011 $208.44
Included In Overhaul Kit.
Transmission Overhaul Kit 0435221011 $524.25
Vehicle Level Maintenance Filters Fluid Filter - A/T Parts Information
Parts Information
Part OEM Part Price
Fluid Filter - A/T
Filter
14 - To 4/98 3533021011 $46.09
14 - 4/98 to 2/00 3533006010 $45.18
Old 07-09-07, 02:34 PM
bkim
bkim's Avatar
Thank you!!
Old 07-09-07, 03:40 PM
Meetya
Meetya's Avatar
What do you mean by "strut mounts with bearings"? The strut mounts are just top parts of strut assembly, how did you damage them?
Just for the reference, each Front Strut Assembly consists of:
- Strut Mount ($48)
- Spring Seat ($18)
- Upper Spring Insulator ($18)
- Strut Bumper ($9)
- Coil Spring ($122)
- Lower Spring Insulator ($14)
- Strut itself ($138)
- Knuckle ($220)
There are no strut bearings! There are bearings in Wheel Hubs though.
Right Strut mount part# 48603-33021 ($48.08)
Left Strut mount part# 48609-33121 ($48.08)
Transmission Pan Gasket part# 35168-21010 ($7.45)
Transmission Filter part# 35330-06010 ($29.88)
You also need 5 quarts of Type T-IV ATF (~ $4 per quart)
Old 07-09-07, 03:46 PM
Meetya
Meetya's Avatar
Originally Posted by L0c0
Part OEM Part Price
This kit includes all clutch steels. You only need this if you are rebuilding the transmission.
I think he only asked for Pan Gasket and the Filter. BTW, filter can be reused, if washed and cleaned with compressed air.
Yeah, let's go crazy!
This kit includes all paper and rubber products, o-rings seals, metal clad seals, gaskets and clutch frictions (clutch steels kit is included).
Old 07-09-07, 04:18 PM
mikey00
mikey00's Avatar
Thanks
No part # cross referencing is needed. Both Lexus and Toyota use the same numbers. For example if a Lexus right strut mount is 4860333021 , you can use the same part # at the Toyota parts counter, as long as it is used in a Toyota model. If it's Lexus specific it will show up as invalid part # and needs to be sourced from Lexus.
Old 07-11-07, 04:36 PM
bkim
bkim's Avatar
- Strut Mount ($48)
- Spring Seat ($18)
- Strut Bumper ($9)
- Knuckle ($220)
Thanks for your help with the part #'s. However, there is a bearing that fits between the strut shaft and the mount. I just bought 2 of them
part # 90903-63014. And it is a true radial bearing with ball bearings in it. I didn't do anything to damage the mounts, they just deteriorate every so often in the rx300.
Old 07-11-07, 05:53 PM
Meetya
Meetya's Avatar
I can be wrong again, but I looked it up everywhere I could. There is no Strut Bearings on 1999 RX300 or any other year RX300. Only 3rd+ Gen ES and RX400h use them. Again, I can be wrong. When I disassemble the front suspension, I will let you know. If there are no bearings between the mount and the spring seat, I am gonna put them there.
1999 RX300 (no strut bearing between the Mount [#12] and the Spring Seat [#11]):
2002 ES300 (#10 is the strut bearing):
bkim, you gave a great topic for DIY-guys! We learn a lot because of you. Thanks!
Old 07-11-07, 06:31 PM
bkim
bkim's Avatar
Hmmmm...The dealer could have brought up the wrong parts diagram for me. Either way I'm doing mine tomorrow, so I'll let you know! You mentioned that you would put one in if there wasn't one. Do you think it would be a benefit to install one if it doesn't originally have one? Thanks again for your help and putting up the diagram. Would you happen to have access to the torque values?
Old 07-11-07, 07:14 PM
Meetya
Meetya's Avatar
Well it is possible that the first picture (for RX300) is not as detailed as the the second one. I just realized that it does not have strut nut (is it part of strut part?), and lag nuts. Let us know if your RX have separate strut bearings or just a lube on the mount as I originally thought. Ask your mechanics to give you the old ones, so you will know for sure.
About the second part. Are you gonna do it yourself?
Which torque specs do you need?
I attached some of them in PDF, but I have all specs from ALLDATA.
File Type: pdf
Old 07-12-07, 07:19 AM
Gomer1
Gomer1's Avatar
This brings me to a somewhat related topic. When I need parts from the dealer, I go to the Toyota dealer, since the same part at the Lexus dealer is about 15% more expensive. The parts guys are always asking me for what car is this, and when I tell them a Lexus they seem not to like it, not sure why. Could someone tell me what year(s) Highlander would have the most common parts with an '01 RX?
Thank you
Old 07-12-07, 07:51 AM
thomas1
thomas1's Avatar
There is a bearing, I replaced mine on my 99 RX300 several years ago. By the way the bearing comes with the mount at several aftermarket parts stores. Cost was around $43 per mount at NAPA
Old 07-12-07, 08:00 AM
Lexmex
Lexmex's Avatar
Thank you
2001-2003 Highlander, but the V6 (1MZFE) 3.0 L version.
Old 07-12-07, 07:58 PM
bkim
bkim's Avatar
99AWD rx300 has bearings under the strut mount. Saw them myself
Mount replacement went well. Much quieter now. Everything was pretty straightforward, Used 3 strut compressors instead of just 2--felt safer.
Quick Reply: Cross referencing lexus/Toyota part #s
