Can you turn off/ deactivate the TPMS light?
Old 08-22-07, 10:55 AM
JTV
JTV's Avatar
Default Can you turn off/ deactivate the TPMS light?
I have a 04 gx that did not have tpms sensors on it when i bought it. I just put new cross terrains and factory oem rims on, but did not add sensors. Can the low pressure light be turned off. Or would you have 4 sensors added? Cost should run around $515 plus install at the dealer.
thx
Old 08-22-07, 11:05 AM
The G Man
The G Man's Avatar
thx
I dont understand your question. If you dont have TPMS, how can u turn off something you dont have.
If you dont have TPMS, you cannot just add the sensor, you also need the TPMS computer too.
Old 08-22-07, 12:03 PM
GatorGreg
GatorGreg's Avatar
I think only the '03s were lucky enough to leave the factory without the TPM system. So since he has an '04 he should have the computer - sounds like he's just missing the $515 (gulp) sensors.
Old 08-22-07, 12:30 PM
The G Man
The G Man's Avatar
Thonks for the clearification. I think the TPMS is very nice to have, $515 would make me think twice though.
Old 08-22-07, 03:22 PM
JTV
JTV's Avatar
The computer is there just no wheel sensors, and for $500 + to make the little yellow tire low press light go off. It just seems a little ridiculous. Heck I only paid $754 for four mich. cross terrains last week at Costco.
I just want to know if I can turn off that annoying little light?
Old 08-23-07, 05:42 AM
The G Man
The G Man's Avatar
That $500 will do more than make the little yellow tire low press light go off, of course, you already know that.
As far as I know, there is no way to turn that TPMS light off.
Old 08-23-07, 09:06 AM
JTV
JTV's Avatar
Besides installing pressure transmiters in the wheels, is there something else the system takes care of that i have over looked?
Old 08-23-07, 09:41 AM
GatorGreg
GatorGreg's Avatar
I think what G Man meant was that the sensors could conceivably save your life - not just turn off an idiot light Have you tried doing a search for "TPMS" on the forum? With all the '04+ folks who've added aftermarket wheels I'd think this subject would have come up before. I would think you could just yank the bulb or the wire going into it from under the dash??
Old 08-23-07, 10:14 AM
The G Man
The G Man's Avatar
I believe someone have try looking for the fuse for the TPMS system and it was tie to other systems in the GX. If you had a wiring diagram, you maybe able to find that wire going to the light. I would think people would want a early warning TPMS on their car after the Firestone tire recall.
Old 08-23-07, 07:28 PM
purplehazek4
purplehazek4's Avatar
This has been something that bugs me too! I'm thinking when i get my GX from the shop, I'll remove the gauge cluster and see if i can just remove the bulb.
Old 08-24-07, 09:49 AM
Capirato
Capirato's Avatar
Dan.....
All you need to do is cut one wire and ground it.
https://www.clublexus.com/forums/showthread.php?t=189307&highlight=tire+light
~ Cap
online
NX - 1st Gen (2015-2021)
11-10-17 07:26 PM
RayKnight
GS F (2016-present)
05-11-17 05:31 AM
Myrix
Wheels, Tires & Brakes Forum
07-05-16 08:59 PM
starknight
11-19-11 10:48 PM
Rickster31
08-01-07 08:03 AM
Quick Reply: Can you turn off/ deactivate the TPMS light?
