How To Change Headlight bulb
Old 09-01-07, 08:41 PM
TORTOISE
TORTOISE's Avatar
Default How To Change Headlight bulb
I tried to change the bulb today and i pulled on the rubber tube that looked to be leadin to the headlight and it just popped off whats the deal? Also i bought H7 bulbs are these right for low beams?
Old 09-01-07, 08:59 PM
LXMN
LXMN's Avatar
H7 is the correct bulb for the low beams.
If you have already popped off the rubber gasket, the bulb is held in with a metal clip. You will need to loosen this clip in order to release the bulb from the headlight.
Old 09-01-07, 09:02 PM
TORTOISE
TORTOISE's Avatar
yeah thats what i thought but i didnt want to break anything...thanks a lot!
Old 09-01-07, 10:41 PM
Xterminate
Xterminate's Avatar
hes right about h7 but somehow mine wont fit with the rubber gasket...... it seems too big for the h7 socket to reach the plug so iunno what happen there........ also the bulb i pulled out was a h4 bulb?!?!?!?!?
but h4 are only for motorcycles only
Old 10-13-08, 08:54 AM
JennGirl
JennGirl's Avatar
Hey guys,
So....I'm going through a divorce and don't have the soon to be ex to change my headlight bulb and the auto store won't help.
I've changed many on my Volvo and Saturn, but haven't attempted with the Lexus.
I know this is silly, but can someone give me "dummy" instructions so I don't break anything? I'm changing both low beams.
I'm sorry. Really appreciate anyone replying.
Old 10-14-08, 10:36 AM
Lexucan
Lexucanafer
Lexucan's Avatar
Originally Posted by JennGirl
Hey guys,
If you've done this on other vehicles, then it shouldn't be too much different on our ES. And being a female, it might even be easier for you than it would for your ex, since your hands are probably smaller than his. Smaller hands are an advantage since there isn't a whole lot of room behind the headlight housings, but if I can do it (and I have pretty big hands) then you should be ok. Just lift the hood on your car and reach in behind the headlight housing and turn the plastic base of the old bulb to unlock it so you can pull it out. The lowbeam bulbs on the '93 ES300 are #9006 halogens. Just separate the old bulb from the wiring harness by depressing the locking tab on the connector ****ALWAYS PULL ON THE CONNECTOR ITSELF, NOT THE WIRES GOING INTO IT**** and then plug in the new bulb ****BE SURE TO NOT TOUCH THE GLASS PART OF THE BULB - FINGERPRINTS WILL SHORTEN ITS LIFE**** Carefully push the new bulb into the back of the housing again and turn it to lock the base into position. Do the same on the other side and you're done.
Old 01-04-09, 06:32 AM
JennGirl
JennGirl's Avatar
Lexucan,
Thanks a bunch!!! I really appreciate it...I try to avoid calling my ex for small things (we are friends....more like annoying family members, but still!)...so I very much appreciate it. I was able to do it....I just didn't know if I should be aware of anything different with Lexus bulb changing. Many thanks for this reply and the others you have replied to for me =)
Jenn
Old 01-04-09, 03:49 PM
Walnut
Walnut's Avatar
Wink
Jenn, you should divorce the Saturn too....
Old 01-04-09, 03:59 PM
Lexucan
Lexucanafer
Lexucan's Avatar
Lexucan,
Glad to be of help.
Old 01-04-09, 11:20 PM
paintrain
paintrain's Avatar
agreed^^^^^
Old 01-05-09, 11:10 PM
Lazy
Lazy's Avatar
same here.
charliedon
Performance & Maintenance
03-19-17 03:30 AM
jagalchi88
RX - 1st Gen (1999-2003)
09-19-11 09:17 AM
Nicelex13
05-20-06 04:23 PM
1BadAzzLex
01-16-03 09:11 PM
kjbro
10-10-02 05:23 PM
Quick Reply: How To Change Headlight bulb
