Cold Start - Grinding/Rattling Noise
I dropped off my IS350 at the dealership to have them check this problem. They heard the noise this morning but claims its normal and refuses to do the TSB fix. Has anyone else experience this? Is there anything I can do at this point? This does not sound like anything normal for a 40K+ car.
Please advise.
Thank you.
Please advise.
Thank you.
I had that TSB fix on that problem about a week ago, it's definitely not normal.
I don't have scanner, so I can't give you the tsib, but this is what it states:
This is what they changed on my engine:
Gear ****, Camshaft
Gasket, timing chain
gasket, camshaft bea
insulator, fuel pump
gasket, cylinder hea
gasket, air surge
Hope this helps.
Immediately following a cold soak startup, some 2006 - 2007 model year IS 250 vehicles may exhibit a brief rattle/knock from the engine compartment for approximately one second. Refer to the repair procedure below to address customer concerns.
Applicable: 2006-2007 model year IS 250 vehicles equipped with the 4GR-FSE engine and produced BEFORE the production Change Effective Vins show below:
IS250
PLANT DRIVETRAIN PRODUCTION CHANGE EFFECTIVE VIN
TMK 2WD JTHBK262*72041664
4WD JTHCK262*72014588
TAHARA 2WD JTHBK262*75027761
4WD JTHCK262*75011435
WARRANTY INFO:
OP CODE DESCRIPTION
EG7027 R & R bank & bank 2 intake camshaft gear assemply
Applicable Warranty*
This repair is covered under the Lexus Powertrain Warranty. This warranty is in effect for 72 months or 70,000, whichever occurs first, from the vehicle's in-service date.
IS250
WARRANTY INFO:
OP CODE DESCRIPTION
Gear ****, Camshaft
gasket, air surge
Hope this helps.
Someone posted this link in the original thread: http://www.sendspace.com/file/rmsm5l
I hear a rattle when I start up my car too. I was thinking that it was coming from the dash or something. It sounds like its coming from somewhere behind the instrument panel.
Hmm.. I'm not sure if I have this problem too but I only noticed it after I installed the Tanabe exhaust... I only hear the noise when a door is open and I cold start the car. If all doors are closed, I can't hear the rattle... I'm pretty sure it's coming from the outside of the car.... Is this the problem you guys had? It sounds like something metallic is loose and only happens when I start the car when it's not hot.
