100,000 mile service !?!?
Old 01-12-02, 07:58 AM
1994 LS400
1994 LS400's Avatar
Default 100,000 mile service !?!?
Hello ~
I am at 99,000 miles on my LS and I am due for service @ 100,000 and some change, and well what do they do (Lexus) @ 100,000 mile service, or is it just a regular service and what is the average cost , thank you !
Paul
Old 01-15-02, 10:40 PM
lexie
lexie's Avatar
Hi 1994 LS400
At 90k miles, you should have your timing belt & water pump replaced.(dealer here charge about $1,300.00) Did you have that done already?
Also you should have your spark plugs replced at 60k miles.The next spark plug replacement is 120k.,
Also it is good to replaced your engine coolant, transmiision, diffenertial. Did you have your brakes fluid replaced recently.
What about air filter? How old is your battery?
Don't forget to check your power steering reservoir because LS400 has a history of power steering leakage. My 91 LS has 68k miles but I'm in my third power steering assembly
that's all I can think of right now
Old 01-16-02, 06:07 PM
Erfan
Erfan's Avatar
Does the water pump make any noises before it is about to go out? I have 94K on my ES300 and I havenot had the water pump changed, the timing belt was changed by the previous owner at 75k. Should I wait till 120K and change the pump or do it sooner?
dragosdor
GX - 1st Gen (2004-2009)
11-10-17 07:58 PM
Natas1979
28
01-13-17 06:51 AM
dmrinehart
10-24-13 07:50 PM
Gomer1
RX - 1st Gen (1999-2003)
22
06-05-09 10:36 PM
99LS400BLK
Maintenance
07-15-05 06:16 PM
Quick Reply: 100,000 mile service !?!?
