How much does your LS400 rotor weigh?
Old 01-08-08, 12:10 PM
JesLet
JesLet's Avatar
Default How much does your LS400 rotor weigh?
My slotted / drilled 95-00 LS400 rotor just came in. I weigh each and it came up to be 21 pounds.
I searched and found TT rotors weigh about 20 lbs each.
Do you know what you guys have?
Old 01-09-08, 04:04 PM
CantSeeMe
CantSeeMe's Avatar
The LS rotors that i have weighed 21.5# ea.
Mine are not slotted/drilled though.
Old 01-09-08, 04:41 PM
JesLet
JesLet's Avatar
Cool. Good to know
I thought 21 lbs is too heavy for a single rotor.
Old 01-09-08, 09:48 PM
SCoupe
SCoupe's Avatar
Do the LS400 Rotors have noticable cooling fins in the center or are they a solid disk?
Old 01-09-08, 10:58 PM
97-SC300
97-SC300's Avatar
they have the cooling fins on my stock LS400 rotors
Old 01-10-08, 12:43 AM
JesLet
JesLet's Avatar
Are not all rotors like that? Are they called "vented" as well?
Old 01-10-08, 09:54 PM
SCoupe
SCoupe's Avatar
"All" rotors vented ?, no. Re the LS rotors, I'm suprised that they they are reportedly heavier than Supra TT as LS are smaller and both rotors are vented.
Old 01-10-08, 11:00 PM
dejacky
dejacky's Avatar
me too, I thought the LS400 oem rotors were lighter than the supra TT ones since they're slightly smaller.
Old 01-12-08, 08:12 AM
CyBorG
CyBorG's Avatar
TT rotors are 17.5lbs
Old 01-14-08, 04:24 PM
pmpdaddyt
pmpdaddyt's Avatar
do they have any ls400 rotors that are just slotted?
Old 01-14-08, 07:06 PM
Mr Soarer
Mr Soarer's Avatar
i have the ATE rotors and i just slapped it on wen i did the LS Brakes but they are heavy
Old 05-26-10, 03:54 PM
sam430
sam430's Avatar
looking for oem part# on these rotor, anyone have them?
Old 05-27-10, 07:45 AM
rwdanthony
rwdanthony's Avatar
idk about rotors, but ls400 calipers are lighter then supra tt.
ls400 calipers are aluminum while supra tt are steel, or cast iron?
anyways. r1rotors or w/e from ebay will make rotors out of dirty metals and your actually better off, and even better performance with an oem rotor.
the dirty metals might posibbly be giving you that extra lb or so.
dont woute me on this info, but i do know the dirty metals, hence also the prone ability to being warped.
wow i just noticed this thread is 2yrs old. haha oh well, theres some info.
Old 05-28-10, 12:21 AM
sam430
sam430's Avatar
do u have the oem part number or spec/dimension?
Old 05-28-10, 11:28 AM
RedPhoenix
RedPhoenix's Avatar
dirty metal? I assume you mean pot metal, which is the the left overs?
Thrustn
12-05-16 12:52 PM
masboy
05-14-10 10:41 PM
CCC-TT
08-11-07 02:10 PM
Quick Reply: How much does your LS400 rotor weigh?
