Check VSC VSC off
Old 01-12-08, 05:37 AM
FYOUNES
FYOUNES's Avatar
Default Check VSC VSC off
I have a 2001 LS430 UL,
my check engine light comes on when its cold, but it goes out after a day or 2, i had my freind check the codes it was P0172, P1125, TPS....
but right after he pullued his snap on scanner, the VSC off and a VSC message appeared. its been a couple of weeks, my check engine light is off, but the VSC off still on, and the cruise control doesnt work either, it says check cruise system, but i think its related to the VSC being on,
is there a way to reset the VSC light ?
thanks
Old 01-12-08, 09:02 PM
onepointon
onepointon's Avatar
thanks
since its a UL, you have laser cruise, correct? there could be a problem with you laser sonar. more than likely the vehicle has codes stored for the VSC system. the dealer can pull the codes for you, but they might charge you. you are really going to need those codes to go any further. did you have the TPS fixed/diagnosed?
Old 01-13-08, 08:29 AM
FYOUNES
FYOUNES's Avatar
I think you have a point,
I had the car checked by the dealer, they said they couldnt find any problem with with the TPS, and there was no engine codes, however they found the other codes, for the YAW sensor, and the laser cruise,
they suggested that the laser cruise is triggered by the Vsc, and they wanted to change the Yaw rate sensor for 870$ total, but i thought that i the light just came on when i had a generic scanner plugged to the car,,
sha4000 (03-24-17)
Old 01-18-08, 04:47 AM
FYOUNES
FYOUNES's Avatar
Well, I guess after reading a lot of threads about the VSC, I need to recalibrate my yaw rate sensor.
my frfreind has a snap on ( solus) sacnning tool, can it be able to reaclibrate the sensor,...dealer quote me 775$ to do the job...
please advise, thanks....
Old 01-18-08, 05:37 AM
gs4mock2
gs4mock2's Avatar
my car had the same problem......a friend had the modiis scanner by snap on and recalibrate it it no time
Old 01-18-08, 07:02 AM
FYOUNES
FYOUNES's Avatar
oh, wow, i think the solus is newer than the modis, so hopefully they he can do it,,,,
Old 01-18-08, 09:58 AM
FYOUNES
FYOUNES's Avatar
does anyone have the instruction how to calibrate the vsc yaw rate sensor??
thanks
roshanvi (03-07-18)
Old 01-21-08, 05:22 PM
FYOUNES
FYOUNES's Avatar
got the problem fixed!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
finally, i reset the vsc light by jumping Ts and Gc connectors, waited till i got a message vsc test,
shut off the car, took the jumper out....voila...lights off,,,,,
telford (06-20-18)
Old 02-18-08, 12:48 PM
anthraciteboy
anthraciteboy's Avatar
So what was the exact procedure you did to get your VSC light off? Where are the Ts and Gc connectors you mentioned? I am having the same problem. Thanks
If anyone else knows please chime in.
Henry
Old 02-21-08, 12:25 PM
anthraciteboy
Anyone have any exact procedures?
Old 02-21-08, 02:26 PM
teamplayer
teamplayer's Avatar
I think this is what they are talking about when resetting the VSC light.
1. Make sure the ignition (key) is in the off position.
2. Locate DLC3 connector (under the drivers side dash) and jump terminals ts and cg. (use old wires lying around).
3. Turn ignition to the on position (do not start vehicle).
4. VSC warning light will turn out for 4 seconds then start to flash.
5. Once the light starts flashing for a few seconds, turn the ignition off and remove jumper wires.
The following 3 users liked this post by teamplayer:
moodyblues (03-27-22), roshanvi (03-07-18), telford (06-20-18)
Old 02-21-08, 02:31 PM
anthraciteboy
Thanks I am going to try this when I get home.
Old 02-22-08, 04:33 AM
FYOUNES
FYOUNES's Avatar
here is the correct Ts and CG
File Type: bmp
The following 2 users liked this post by FYOUNES:
Old 02-22-08, 11:50 AM
teamplayer
teamplayer's Avatar
Opps. Did I give the wrong terminals? Sorry about that fellers.
And thanks for the heads up FYOUNES.
telford (06-20-18)
Old 08-30-08, 09:46 AM
DavidinCT
DavidinCT's Avatar
This is an old post but, I had my check engine light checked. As soon as the next time I started the car, the Check VSC would come on, disabling VSC. I tried this reset and it works now.
Thanks !!!!
JRap1952 (01-07-18)
Quick Reply: Check VSC VSC off
