Rx330 Brake Pads replacement
Old 03-26-09, 03:50 PM
  #46
LEXMICK
LEXMICK's Avatar
Has anybody done manual brake bleeding on RX 330 successfully? Do I still have to put 1" x 4" piece of wood underneath the brake pedal to not let the pedal touch the floor when my assistant hold it down when I open the bleeder valve to avoid damaging the master cylinder? I have read a lot of articles about the need of putting the piece of wood, but some consider this practice unnecessary. Any information will be appreciated. Thanks.
Old 03-29-09, 01:06 PM
  #47
Grumpa72
Grumpa72's Avatar
I have been bleeding brakes for 25 years on everything from my 43 year old Corvette to my wife's Acura. Never heard of the need for a wook board. And, I have never had a problem with bleeding brakes either.
Old 03-29-09, 02:40 PM
  #48
compdr59
compdr59's Avatar
Hi,
You did a great job describing your brake pad replacement. I did mine about a year ago and now I'm having a soft and low brake pedal on my RX330. I saw that you posted the diagrams of the front and rear brake components. If it wouldn't be too much trouble, could you please email the pages to me so I can make sure all of the brake hardware is installed properly. My email is manhouse@optonline.net
Thanks
Old 03-29-09, 03:21 PM
  #49
mandyfig
mandyfig's Avatar
Do you need the front or the rear?
Old 03-30-09, 05:20 AM
  #50
compdr59
compdr59's Avatar
Both please.
Thanks,
Mark
Old 04-04-09, 03:02 PM
  #51
compdr59
compdr59's Avatar
Hi Mandyfig,
When do you think you will be able to send the diagrams to me?
Thank you in advance.
Old 04-05-09, 12:26 PM
  #52
mandyfig
mandyfig's Avatar
Front Brake Components:
File Type: pdf
prech (01-02-20)
Old 04-05-09, 12:27 PM
  #53
mandyfig
mandyfig's Avatar
Rear components:
File Type: pdf
prech (01-02-20)
Old 04-05-09, 01:28 PM
  #54
compdr59
compdr59's Avatar
Thank you.......
Old 05-12-09, 10:50 AM
  #55
Hayk
Hayk's Avatar
RX350AWD
I have about 2-3mm left on the front brakes(they haven't made any noises yet though). Found out when I was bleeding the brakes. I emailed my Lexus dealer for parts and they quoted me $73.75 + tax for the front pads. Seems like it's really expensive, is this a good price? Would it be cheaper/better to get something from a local auto parts store?
p.s.: Can somebody give me a direct link to the front pads on Sewell? I searched on their site and about 20 results came up. They all look the same, which ones do I need?
EDIT: nvm, ordered them off Sewell for around $54(with a 15% discount)
Old 05-21-09, 11:03 AM
  #56
Spadriver
Spadriver's Avatar
My mechanic just advised me that my front brake pads are down to 4 mm and should be replaced. I checked out your explanation and pictures and found that I can do the work myself. Thanks for the clear explanation.
Old 05-21-09, 12:10 PM
  #57
mandyfig
mandyfig's Avatar
You are quite welcome, if you were referring to me.
Old 05-21-09, 12:12 PM
  #58
mandyfig
mandyfig's Avatar
Just a note, brakes are safety related components, unless you think you are qualified to do it, please leave it up to the pros. Just a reminder that most of what you read in forums like these are for reference and it is at your risk that you follow them.
Old 05-21-09, 12:56 PM
  #59
Hayk
Hayk's Avatar
It is so straight forward, it's really hard to mess something up. The hardest part was just not gettting any grease on the brake pads/rotors since it started coming out when I was pushing them back in.
Old 06-24-09, 06:14 PM
  #60
bagsbie
bagsbie's Avatar
I need to replace rear brake pads on my RX330 and have a question. Are the caliper pistons a rotating type or pushing type like the fronts?
Quick Reply: Rx330 Brake Pads replacement
