check VSC and engine light on dashboard
Old 02-10-08, 04:58 AM
sense
sense's Avatar
Default check VSC and engine light on dashboard
i confused what problem can be happened....
my car ES350 2008 NEW about 2000 miles
Old 02-10-08, 05:19 AM
ES350Bob
ES350Bob's Avatar
Welcome sense,
I have seen this reported several times on GS forum for 08 models.
Try loosening and then securely tightening your gas cap.
Then restart the car and see if that solves it temporarily.
I'll look for GS thread I read and put a link here in case you don't find it.
I have seen in mentioned quite a few times and requires a service appointment but seems applies to 08 models.
Old 02-10-08, 05:30 AM
sense
sense's Avatar
Originally Posted by ES350Bob
Welcome sense,
thank's my friend
but how loosening gas cap
Old 02-10-08, 05:36 AM
ES350Bob
ES350Bob's Avatar
Originally Posted by sense
thank's my friend
Just act like you are going to put some gas in it and open gas cap as you usually would, then just put gas cap back on real tight.
It is a mix of LS and GS owners from what I have read, and here are two posts on the subject. I could not find the 08 GS mentions as they are mixed in among other topics but if you look on GS forum you should find. But here is a list of what one guy's dealer did.
https://www.clublexus.com/forums/sho...d.php?t=331770
"""""BmoreGS4;3258649]I had the same issue I found that it causes so many codes that often the dealership may just clear the code and send you on your way. I finally found a great service consultant who did EVERYTHING until he made sure it wouldn't happen again.
here is what was done 2 months ago and never happened again to me, after happening 3x's in the 3 weeks after I bought my car...
-Leaks detected @ the vacum switching valve and gas cap replaced
-Replaced PCV Valve and calibrated
1 thing you should never take for an answer is your gas cap is loose, even if you 4got tell them u didn't, so they can thouroughly check your vehicle...The gas cap is often a cop out IMO..."""""
https://www.clublexus.com/forums/sho...d.php?t=334349
Old 02-10-08, 05:48 AM
ES350Bob
ES350Bob's Avatar
sense,
almost forgot, if that is not a temp solution then could be something else. It is not wise no matter what it is to drive it with it displaying the warning lights.
It can happen as well if your car has had transmission slips you have noticed, or significant delays in shifting, then later can result in dash lighting up.
Old 02-10-08, 01:24 PM
sense
sense's Avatar
thank's ES350Bob
I wil try , if light's is take off i kiss your hand my friend
Old 02-10-08, 01:27 PM
ES350Bob
ES350Bob's Avatar
thank's ES350Bob
You are welcome. Even if it works, still let dealer know it happened...
and keep us posted on it no matter what it is.
Old 02-10-08, 04:10 PM
onepointon
onepointon's Avatar
I would definitely take it to the dealer to have them read the code.
For information, a loose gas cap is a legit problem. The problem though is that it is commonly misdiagnosed. Evaporative Emissions codes are sometimes hard to diagnose, so some techs just write it off as that and send them on their way. Especially if the vehicle is under warranty. Also, your ES350 has what we call a "key-off" system. Five hours after the vehicle is turned off, the vehicle runs its own checks on the system, instead of previous models that required engine vacuum to run its checks. So its a little different of a system.
Anyways, its actually quite complicated and simply tightening your cap may not immediately get rid of your CEL. Sometimes it takes quite a few warm up cycles for the engine computer to say "ok, its fixed", vs taking it to the dealer and having them read it and clear the codes with the scan tool.
That was longer than I thought, sorry.
Cliff notes: take it to the dealer to have checked.
Old 02-11-08, 08:31 AM
NJLEXES
NJLEXES's Avatar
Is the car shifting alright (not shifting rough or overreving)?
When my "CHECK VSC message" and "CHECK ENGINE light" came on, it indicated my transmission was shot.
Granted this happened at 19000 miles on my ES350.
Good luck
Old 02-11-08, 11:25 AM
onepointon
onepointon's Avatar
Good luck
The "Check VSC" automatically comes on with any hard DTC (Diagnostic Trouble Code). What was the code that your vehicle had? Really, a check engine light could be anything from a loose gas cap (P0440, P0441, P0446, ect), to misfires, camshaft position sensors.. ect. The list is a mile long. Its all just shoot in the dark until you know what the DTC is.
Theres no way to guess what it could be. This is why I suggest taking it to the dealer. It should be still under warranty, therefore they should not charge you for looking at the code, much less fixing the problem. At the very least you can go to autozone or something similar, post up the code, and I can let you know what it is/what the problem could be.
Old 02-11-08, 01:40 PM
NJLEXES
NJLEXES's Avatar
As far as the codes in my case....
P0746 Pressure Control selenoid "a" Performance (shift selenoid Valve SL1) Monitor description
P0796 Pressure Control selenoid "c" Performance (shift selenoid Valve SL3) Monitor description
P2714 Pressure Control selenoid "D" Performance (shift selenoid Valve SLT) Monitor description
Old 02-11-08, 09:57 PM
codex57
Rominl Stalker
codex57's Avatar
Happened a couple months ago on my Honda. Loose gas cap. Discovered this when I went to fill up. Took several cycles before the warning light went away. Like a week or week and a half.
Old 02-12-08, 11:09 AM
toneman
toneman's Avatar
Slightly OT--when the vehicle runs its "key-off" check five hours after the vehicle has been turned off...is it running the check even though the vehicle is still off, or does it run the check the first time the vehicle is turned on after having been off for five hours?
What happens if it's unable to run its key-off check for whatever reason...does it spit out some kind of check engine code?
Old 02-12-08, 04:54 PM
sense
sense's Avatar
i have appointment in my dealer on monday 18 feb
and also i know the code in my case can you explain what the problem could be?
1- P2241
2- B1421
3- B1424
thank's for all
Old 02-19-08, 05:21 PM
sense
sense's Avatar
1- P2241
2- B1421
3- B1424
thank's for all
the dealer told to me today and he was not know the cause of these code
and he told to me send that to lexus in Japan and then call me about these
any body have a idea about these
Quick Reply: check VSC and engine light on dashboard
