VSC and VSC Off Lights - Limp Mode
Old 07-24-09, 07:21 PM
Jeffna
Jeffna's Avatar
Installed the throttle control motor to no avail. It did not work. I will be replacing the TPS sensor next week.
Old 07-25-09, 02:03 PM
cpone
There can only be One
cpone's Avatar
I changed the tps and the motor and am still getting the same codes here to. P1120 and P1121. It's been two weeks with this problem and am running out of options.
Old 07-25-09, 05:43 PM
lilsharky
lilsharky's Avatar
try replacing the lever assy throttle. part no. 22060-46010. after i changed it my car worked fine...before dat i replaced the tps wit no luck.
Old 07-26-09, 07:07 AM
cpone
cpone's Avatar
Thanks I will try that.
What was the cost on that?
Reason I ask is because I was gonna try swapping out the Accelerator pedal sensor. Its the only other thing I have not swapped out.
Old 07-26-09, 06:14 PM
lilsharky
lilsharky's Avatar
it cost me 445 including labor. you can get one at sewell for 260 + tax. the mech called and asked for the accelerator pedal position sensor but the dealers didnt know what it was including carson. so you probably have to describe it or something.
Old 07-30-09, 04:50 AM
Jeffna
Jeffna's Avatar
CPONE any luck? I just replaced the TPS and the Throttle control motor to no avail. I really dont want to spend $270 on the the Accel pedal position sensor to find out it doesnt work.
Old 08-01-09, 01:27 PM
Jeffna
Jeffna's Avatar
Anyone? Anyone?
Old 08-01-09, 08:09 PM
frankjames
frankjames's Avatar
http://bahamutcars.free.fr/workshop/...nts/index.html
You can test the different parts using an multimeter the link above can tell you the resistances that are in tolerance. You don't have to just guess and blindly replace parts this way it walks you through step by step. Hope this helps. Had same issue awhile back.
Old 08-02-09, 02:01 PM
Jeffna
Jeffna's Avatar
I will try this tomorrow. Thank you. I dont know how to use a multimeter tester but I will figure it out
Old 08-02-09, 03:35 PM
frankjames
frankjames's Avatar
How to use a multimeter..... http://www.multimeterwarehouse.com/u...r.htm#analogue
Old 08-03-09, 07:35 AM
Jeffna
Jeffna's Avatar
FrankJames...you are the man. Thank you very much. I checked resistance on the Accell Position Pedal Sensor and it was fine. But Im still getting code P1120 Accelerator Pedal Position Sensor Circuit.
Previously I was getting code P1120 and P1121. As soon as i replaced the TPS, code
P1121 was gone.
Any other suggestions that can lead to this code? So far I replaced the TPS and the Throttle control motor.
Old 08-03-09, 01:47 PM
frankjames
frankjames's Avatar
Disconnect battery for ten/fifteen see if still throws code. did u check to see if throttle body is clean?
Old 08-03-09, 08:11 PM
frankjames
frankjames's Avatar
also check for excessive play in Accelerator Pedal Position Sensor.....heard of cases, especially where you have a lead foot that this can happen too(cable is stretched out)
Old 08-08-09, 07:24 AM
frankjames
frankjames's Avatar
any luck????
Old 08-11-09, 07:22 AM
Jeffna
Jeffna's Avatar
I decided not to fix the Accel Pedal Position Sensor. I still have the same code. I am trading the car in on the 23rd. The Honda Dealer gave me $4800 for a trade in. I rather not fix the problem. My schedule is too busy. I know the car is safe and sound once I replace the the sensor but its my girls car. She wants to upgrade. I plan on posting the car for a week or more. I rather give the opportunity to a CL member than to give lowballing dealership. $5000 is my target price.
Quick Reply: VSC and VSC Off Lights - Limp Mode
