Lug pattern on the 07 LS 460
Old 04-27-08, 07:48 PM
houstonsc4
houstonsc4's Avatar
Default Lug pattern on the 07 LS 460
Hey does anyone here know what the Lug pattern is ?
I am trying to put some 22'' from a 06 Gs 430 on the 07 LS 460,
Will it work ?
Thanks Jimmy
Old 04-27-08, 08:12 PM
Gojirra99
Gojirra99's Avatar
No it won't work. The LS460/600hL have a different bolt pattern from all other Lexus models : 5 x 120 .
It's 5 x 114.3 for all other Lexus models including the 06 GS430.
Old 04-27-08, 09:43 PM
rominl
exclusive matchup
rominl's Avatar
yes, and also the studs on the ls460 are different as well
Old 06-28-16, 07:28 AM
steelers6
steelers6's Avatar
So when im looking for rims for my 460 or 600 the bolt pattern is simply 5 x 120????
Old 06-28-16, 07:35 AM
roadfrog
roadfrog's Avatar
Correct. The only other issue is offset. You need the correct offset to prevent rubbing.
Old 06-28-16, 08:22 AM
steelers6
steelers6's Avatar
Ok but how will i know what the correct off set is???
Old 06-28-16, 09:01 AM
brianlin87
Resident JDM Snob
brianlin87's Avatar
This thread sticky here should answer all your questions.
https://www.clublexus.com/forums/ls-...ls-thread.html
Old 06-28-16, 11:17 AM
roadfrog
roadfrog's Avatar
The link provided above will help you. Keep in mind that offsets can be played with quite a bit, through the use of spacers, etc. For example, I installed 20" wheels that I had on my previous BMW 7 series. The offset was far more aggressive than my Lexus would normally permit, but I adapted them with the help of rolling the fender wells. Anything is possible with enough determination, money, ingenuity and aftermarket parts.
This may help: http://autotk.com/wheels/lexus/ls-460/
Old 06-28-16, 11:25 AM
steelers6
steelers6's Avatar
Ok cool,great info,thanks
Old 12-14-20, 08:32 AM
Bogosh717
Bogosh717's Avatar
Default 2013 ls 460
Can someone help please. I have a 2013 ls 460 f sport with 19inch rims and looking to put on 20's from a 2018 ls500. Will they bolt on ?
thanks
Old 12-14-20, 08:30 PM
lwphat66
lwphat66's Avatar
thanks
The bolt pattern is 120mm also, so they should bolt up without issue. However, I believe the offset is +25mm, so the wheel is going to be positioned outward more and may rub (when suspension is compressed) on the underside fender lip, depending on your suspension set up.
Old 12-15-20, 06:53 AM
Bogosh717
Bogosh717's Avatar
OK. Thank you for the information. I do have the air ride so maybe I can make it work.
GSP02LS430
03-10-12 11:04 AM
melymel96
11-24-09 02:40 PM
Slvr surfr
11-08-09 06:28 AM
jr1966
11-17-08 10:44 PM
bigcory
04-15-08 07:30 AM
Quick Reply: Lug pattern on the 07 LS 460
