Solution to Creaking Front End Problem W/ Pics
Old 05-19-08, 05:30 PM
UpInTheLex
UpInTheLex's Avatar
Default Solution to Creaking Front End Problem W/ Pics
Ok, guys.....
Previous symptoms:
A creaking/popping noise is heard from the front end of the SC400 while braking at slow speeds. Ex: after shifting from forward to reverse and vice versa while pulling in or out of parking spots. Slightly more than light braking while approaching a stop sign.
Attempted repairs: New lower control arms incl. lower ball joints
New upper control arms incl. upper ball joints
New sway bar end links
New sway bar bushings
New steering rack bushings
New Shocks and springs
Nothing worked!!! or worse
The solution:
Retorque the (4)17mm nuts which hold the aluminum crossmember(cradle) onto the unibody chassis.The 4 17mm nuts should be torqued down to 94ft/lbs.
Another to check while you're under there are the (6) 19mm bolts which hold the steel crossmember located rearward of the aluminum crossmember. The 6 19mm bolts should be torqued to 148ft/lbs.
A 17mm deep socket/19mm socket, 6" extension, and a long handled ratchet will do the job just fine.
Attached Thumbnails Solution to Creaking Front End Problem W/ Pics-850a0229.jpg
The following 2 users liked this post by UpInTheLex:
maoslarx33 (09-04-22), ShaWTiMe (03-29-20)
Old 05-19-08, 05:32 PM
UpInTheLex
UpInTheLex's Avatar
The following posts show the locations of the two 17MM bolts you'll need to retorque. There's a front and rear on both the left and right sides for a total of 4 nuts altogther.
Attached Thumbnails Solution to Creaking Front End Problem W/ Pics-850a0230.jpg
Old 05-19-08, 05:34 PM
UpInTheLex
UpInTheLex's Avatar
Location # 2 ; The rearward most nut.
Attached Thumbnails Solution to Creaking Front End Problem W/ Pics-850a0231.jpg
Old 05-24-08, 08:08 AM
slappy96
slappy96's Avatar
Default I'll try it
Hoping for the best on this. I also have replaced LCA's and went to a supra/bilstein coil. Still have a little clunk from the front right. Same parameters as you describe as well. Thanks. I'll tighten them this weekend and reports back.
Old 05-24-08, 01:31 PM
TheMole
TheMole's Avatar
Cool, I'll check mine out next time I am under there.
Old 05-27-08, 12:43 AM
GS4VIPbOSS
GS4VIPbOSS's Avatar
Will give it a try as this week.
Old 06-08-08, 08:56 PM
SH_JZZ30
SH_JZZ30's Avatar
I will check this out tomorrow. I changed control arms and rack bushings and I still hear a slight clunk coming out of my driveway. Its coming from the front passenger side.
Old 06-09-08, 10:54 AM
SH_JZZ30
SH_JZZ30's Avatar
OK I just torqued them down and NO MORE clunking when driving out of my driveway!!!!!
I can't believe it was that simple. I didnt even jack up the car. I just turned the wheels and laid on the side and tightened them. Took about 5-10 minutes.
Thank you UpInTheLex for this tip.
Old 06-12-08, 09:30 PM
LexAnt
LexAnt's Avatar
and the proper torque setting is?
Old 06-13-08, 05:07 AM
RedPhoenix
RedPhoenix's Avatar
Ill give it a shot this weekend!
Old 06-13-08, 06:58 PM
UpInTheLex
UpInTheLex's Avatar
Tight..........
We're not assembling a bottom end of an engine here.
Ok fine, I won't be an ***. 60-70 ft/lbs seems reasonable if tight doesn't do it for ya!
Old 06-14-08, 11:24 AM
YeA 2jZ
YeA 2jZ's Avatar
good info will try this when i change my brakes
Old 06-16-08, 09:16 AM
RedPhoenix
RedPhoenix's Avatar
You win. Good job man. I didnt get it entirely tight because I didnt have my airtools with me, but yup, its loose. So Ill hit it with the impact whenever I get the chance.
One thing is, are they both 17mm? One is 17mm the other is a lot larger...
Old 06-16-08, 12:00 PM
TheMole
TheMole's Avatar
All 4 of them were 17mm on mine. Might need a deep socket though as the ones I had barely reached.
Old 06-16-08, 12:07 PM
UpInTheLex
UpInTheLex's Avatar
So the popping/clunking/creaking noise is gone now?
The 4 Aluminum subframe nuts are all 17mm.
However, the black painted steel Tranny crossmember behind it has larger bolts.
The front 17mm nuts are easy to find.
The rearward ones are a little sneaky... You have to slip around behind the lower control arm to find it.
Definitely use a 17mm deep socket.
Quick Reply: Solution to Creaking Front End Problem W/ Pics
