SC430 Spare tire Kit substitute!!!!
Old 08-05-09, 12:19 PM
  #61
TooCoolSC
TooCoolSC's Avatar
Originally Posted by farkas
Out of the kit you will use the Wheel, tire and cover. The rest of it can be tossed or resold. If you look at the first few pictures in this post, you will see how this all fits. I am using a rubber bungy cord to hold it in place and it is rock solid.
Oh, so you didn't use all the other pieces of the kit you have placed around the tire in the first picture?
Old 08-05-09, 05:37 PM
  #62
farkas
farkas's Avatar
Thats Correct! I sold it on Ebay for $100.....
Old 08-08-09, 01:03 PM
  #63
TooCoolSC
TooCoolSC's Avatar
Do not understand why you would go to the hassle to find a supra wheel and then buy the tire for $225 when you can get the RX8 kit for $250 that has everything included! Plus it is an alloy wheel that is lighter and looks 100% better than the tan/yellow supra wheel. It also has a cover included that makes it look like it belongs in the car.... But I guess to each his own thing!
I just bought the RX8 spare tire and cover, without all the rest of the kit. I found it on craigslist and the guy sold just the wheel/tire and cover to me for $180. You don't have to have the bracket and all the hardware the RX8 spare tire kit comes with, especially if you're not planning on even keeping it in the car most of the time.
The tire fits perfectly down into the well, and with the cover that it comes with, it truly looks like it's made for the car. The spare is very light, and with the cover, it's very clean. You can lift it in and out of the car and not even get your hands dirty. And it's so light, it doesn't even raise a sweat. But the real test was whether the top went up and down with no problem, and it certainly does. I don't think there can be any better alternative.
The recommended spare is T145/70R17, and this one is T125. If that's a concern to you, then hold out and try to find the Toyota Supra TT spare. But like farkas said, it's not like you're going to be driving a long way on this spare. It only needs to get you to the nearest tire store, so it should suffice.
Old 10-18-09, 08:10 AM
  #64
azkaty
azkaty's Avatar
Default Spare tire DYI
Farkas,
Thank you soooooooooo much!!!! I will follow the lead, and will make a template for the tool kit cover, will cut the carpet to match, and will take to a local upholstery shop to have it bound...will get back to you with the results...
Bob
Old 10-18-09, 12:00 PM
  #65
Harold57
Harold57's Avatar
Before you go and cut the carpet and mat, you might want to check with the upholstery place to find out how much they will charge. It may wind up being cheaper just buying one from Sewell or someone like that.
Old 10-18-09, 12:23 PM
  #66
TooCoolSC
TooCoolSC's Avatar
Here's the cheapest one I found....
http://lexus.dealerfit.com/store/lex...od397_3374.php
Old 10-18-09, 01:01 PM
  #67
Harold57
Harold57's Avatar
Good find TooCoolSC. I just went and entered the part numbers for the mat, cover and trim in Sewell's website and couldn't find them any longer. I found them on Friday and today they're gone. Hopefully, they are just servicing their website right now or something. Rather odd.
Do you have sources for the rest of the spare tire kit?
1 51900-91705 Carrier Assy, Spare Wheel
1 51913-24020 Plate, spare wheel mounting
1 51938-24010 Bracket,spare wheel carrier mounting
4 90105-06158 Bolt
2 90541-09101 Cushion
2 90541-09080 Cushion
1 64711-24170-BO Matt, luggage compartment trim, rear
1 64716-24080-BO Cover,luggage compartment trim, rear
1 64771-24040-BO Cover, spare wheel
Old 10-18-09, 02:35 PM
  #68
TooCoolSC
TooCoolSC's Avatar
No, I don't. I looked for separate items by part numbers to see if someone could pick and choose what they wanted, but couldn't find anything except the mat and wheel and the entire kit.
If someone is going to opt for the entire kit, be sure and enter the code for CL members in order to get the 10% discount. I believe they are still doing that. The code is CL911M.
Old 03-11-10, 12:55 PM
  #69
abbeyrd
abbeyrd's Avatar
Is it a 1998 Supra spare that fits our Sc 430 as a spare?
thanks
Old 03-11-10, 04:50 PM
  #70
TooCoolSC
TooCoolSC's Avatar
Yes, it's the spare from a 93-98 Toyota Supra Twin-Turbo. It's T145/70R17. This is the size Lexus recommends for the spare and the size you'll get if you buy the expensive spare tire kit from Lexus.
So that's the main one people look for. I also read somewhere that a 2004 Acura TL tire/wheel would work, as it's also T145/70R17. I haven't verified that, though.
Another option is the RX-8 spare tire. It works, but is a little smaller (T125/70R17). One good thing about it is that it comes with an elastic cover that just fits around the tire, and it fits snugly down into the wheel well in the trunk. Some people secure it with a bungee cord, but it fits snugly as is.
My spare is usually in my garage. I only put it in on longer trips.
Old 03-11-10, 07:03 PM
  #71
Solman
Solman's Avatar
Default OEM only
Sorry, folks, I decided not to skimp. Paid $630 for the kit from the dealer which included everything. Its a lexus product, matches carpet and hardware, and was very easy to install and left me with carpet parts that i've kept but could have resold. My reasoning is that I purchased my 02 in June 08 for $27K with only 23K miles on it. At that price I could afford Luxlink, new wheels, Aud/video mods, rear window mod, and the wheel kit. The lexus throws in the trunk are for covering the back seat when I need to put packages back there. They match ecru (but not the trunk) and have the lexus logo on them. I'm still under $30k and other than wheels will keep it stock. This wll either be a lifer or will be replaced by a 2010 in 2015. No regrets about $630. I feel my moneys in the right place.
Attached Thumbnails SC430 Spare tire Kit substitute!!!!-dsc03231.jpg   SC430 Spare tire Kit substitute!!!!-dsc03232.jpg   SC430 Spare tire Kit substitute!!!!-dsc03233.jpg   SC430 Spare tire Kit substitute!!!!-dsc03234.jpg   SC430 Spare tire Kit substitute!!!!-dsc03235.jpg
Old 03-11-10, 07:04 PM
  #72
Solman
Solman's Avatar
Default More pics
Very happy with my choices
Attached Thumbnails SC430 Spare tire Kit substitute!!!!-dsc03236.jpg   SC430 Spare tire Kit substitute!!!!-dsc03237.jpg   SC430 Spare tire Kit substitute!!!!-dsc03238.jpg
Old 03-11-10, 07:18 PM
  #73
Pepper2
Pepper2's Avatar
I have an 02 as well. Replaced the run flats with G'year GTs (huge improvement). That said, a donut for trips would be nice. I had thought about "Fix a Flat" spray but I understand that screws the pressure sensors. So the RX8 donut works?
Old 03-12-10, 04:56 AM
  #74
farkas
farkas's Avatar
Yup! Read the beginning of the thread.
Oem is very nice if you have the $$$ for it.
Old 03-12-10, 09:47 AM
  #75
abbeyrd
abbeyrd's Avatar
Just purchased a T145/70 17 Goodyear spare from Tire Rack and a Supra TT spare wheel from Toyota Parts bin. Wheel was 1/2 the price that a Lexus and Toyota dealer were asking. Tire was also cheaper than the Bridgestone version. I look forward to getting rid of the RFT's. Probably leaning towards the Mich Pilot A/S. Just plan to carry the spare on long trips.
Quick Reply: SC430 Spare tire Kit substitute!!!!
