Cold Start, Engine Noise, TSIB EG7027
Old 10-14-08, 06:34 AM
Sparkplug
Sparkplug's Avatar
Default Cold Start, Engine Noise, TSIB EG7027
Cold Start Engine Noise TSIB EG7027
My 07, GS 350 with 25k miles, caught it.
Does anyone know the details about this?
It looks like from other posts that they pull the heads off the engine. (new head gaskets in parts list)
There must be a problem with the camshaft gear, I'm wondering if it worth repairing, or live with it.
Any ideas on long term results from this problem? I hate to have a new motor torn down for some intermittent noise.
After all, sometimes the surgery causes more problems then the disease.
Thanks for your feed back.
Spark Plug.
Copy of another post:
Just got my toy back from dealer for "TSIB EG7027 ENG KNOCK @ COLD START" and "TSIB EG020-07 UPDATE VVTI ACTUATORS".
For TSIB EG7027, they replaced the followings:
-gear assy, camshaft;
-gasket x 3;
-gasket, timing chain;
-gasket, camshaft bea;
-insulator, fuel pump;
-gasket, cylinder hea x2;
-gasket, air surge ta.
Hour: 6.0
Old 10-14-08, 12:56 PM
vladbph
vladbph's Avatar
The problem is that in time it is getting worth and worth. Did it, so far so good. Just ask if they already did it to make sure that you are not a guinea pig.
Old 10-14-08, 02:59 PM
rkb43
rkb43's Avatar
At 16K, I don't have a problem. If it surfaces, I will have it repaired without hesitation.
Old 10-14-08, 05:57 PM
I8ABMR
I8ABMR's Avatar
I hear it rarely , but it doesnt bother me to much. it last for 3 seconds. I have to admit I dont usually have the windows down when I start my car. I dont want damage to happen in the future, I will have them look at it
Old 10-14-08, 07:36 PM
lxgs4
lxgs4's Avatar
The heads don't come off the vehicle. Those are the valve cover gaskets. It would take a lot longer than 6 hrs to remove and reinstall the heads on this motor.
Old 10-14-08, 07:51 PM
dunnojack
dunnojack's Avatar
can someone describe the noise?
i just want to know what to listen for.
nevermind. i found a sound clip. it sounds like an old benz.
Old 10-14-08, 09:49 PM
vladbph
vladbph's Avatar
Here it is:
http://www.youtube.com/watch?v=pBsVeesr9Y0
Old 10-14-08, 10:30 PM
Heng350
Heng350's Avatar
eeeww that sounds gross....somethings difinitly wrong
Old 10-14-08, 10:38 PM
07350FROST
07350FROST's Avatar
believe me.....it was freakin embarrassing as hell.
my car did that for about 6 months when i was trying to get 2 dealerships to take car of it. Westminster Lexus finally did the TSIB and havent heard the noise since...knock on wood.
Old 10-14-08, 11:07 PM
I8ABMR
I8ABMR's Avatar
what I am hearing is no where near that loud. Its like a clicking noise for 2-3 seconds then it stops. I will consult with the service rep. My guy is solid. If its not going to do dmage I would rather not to open up a new motor
Old 10-14-08, 11:43 PM
jwin
jwin's Avatar
they take off the timing chain and everything they change out a cam gear or something like that its takes a really long time more than 6 hours about 8 plus its pretty hard thing its a personal thing to have it done... its ok if you don't and most dealership would rather not do it because its hard to do and the mechanics don't like doing it cause they lose money they only get paid for 6 but it takes a longer. Its not a recall so if you complain about it they will end up doing it for you.
Old 10-15-08, 09:35 AM
dunnojack
dunnojack's Avatar
they claim this causes no mechanical damage. ha yeah right??
it puzzles me that it doesn't do this when new.
the parts are probably not worn out, and everything is probably the same to the naked eye.
yet it makes this nasty sound after a few 10000 miles.
Old 10-15-08, 10:14 AM
dtrose
dtrose's Avatar
Does anybody have the actual copies of these TSB's? I've checked www.lexustsb.com but do not see it there.
Old 10-16-08, 06:00 AM
boxcarfan
boxcarfan's Avatar
i have the actual TSIB for this any of you guys want it...its too big to upload on here...so ill just email to who ever wants it.
Old 11-12-08, 07:54 PM
jaxgs350
jaxgs350's Avatar
My 07 is in the shop for this warranty repair as I type this... the sound started up around 15K miles and I now have 34K on the car. We thought it was some sort of exhaust or heat shield rattle a while back, but now with this TSB and some history of this noise at the dealer on other IS350 and GS350 motors, they knew what it was right away.
At least I have a 08 GS350 loaner for 2 days ;-)
(man I miss my XM radio & Ipod though.... LOL )
caddyowner
04-03-12 08:32 PM
jgonx213
02-08-12 08:16 AM
realchimer
01-09-12 08:26 PM
nyardich
ES - 5th Gen (2007-2012)
17
01-05-11 11:33 AM
Aldo
Performance & Maintenance
07-04-02 12:47 AM
Quick Reply: Cold Start, Engine Noise, TSIB EG7027
