LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
Steering Noise
Old 10-26-08, 07:26 AM
blackdog69
blackdog69's Avatar
Default Steering Noise
I see someone wrote in about a steering squeak when the wheel is activated in and out, (see https://www.clublexus.com/forums/sho...teering+squeak)
but my noise occurs when the wheel is turned, especially in early morning.
My 2000 LX470 was brought in for service on this 2 times, but it was never fixed. Out of warranty now.
Any solutions. Sounds like I need grease near rear of wheel somewhere? You hear the harsh grinding squeak on first 2-3 revolutions.
Old 10-26-08, 12:52 PM
dj sohbash
dj sohbash's Avatar
mine does this too.. i was thinking it might be the clock spring ( the airbag wire case ) but not sure
Old 02-09-11, 09:22 PM
glenwell
glenwell's Avatar
that exactly what happen to my lx470,it the spiral cable,after few months the horn got a problem,turn to left,it blows,when going to right its gone,open it check and test,100% spiral cable.only the horn side got broken,airbag cruise control,is ok.
Old 02-10-11, 09:41 PM
Lexus49
Lexus49's Avatar
Default LX470 Steering Wheel Noise
Greetings from SoCal! I'm new here and I had the same issue. Here are the comments from my service repair work order:
CONCERN: Customer states steering wheel makes noise when turning.
CAUSE: Verified concern. Removed air bag and steering to check clock spring. Found clock spring to be noisy and needs to be replaced. Slight noise still in steering due to steering angle and reluctor wheel.
CORRECTION: Installed new clock spring; noise found to be normal due to age & condition of vehicle.
My comments: Although the main noise is no longer present, there is a slight noise that isn't much to worry about. Better than it was before.
-Lexus49
ssjkev16
11-22-22 11:09 PM
bigcory
12-18-11 07:04 PM
metalgear
12-12-10 03:28 PM
purebliss
ES - 5th Gen (2007-2012)
10-09-06 08:28 AM
right RX
RX - 1st Gen (1999-2003)
02-14-06 02:01 PM
Quick Reply: Steering Noise
