GPS Navigation Update
Old 10-26-08, 10:17 PM
sryan423
sryan423's Avatar
Default GPS Navigation Update
Do you have to go to the dealer to update the Navigation?
Old 10-27-08, 09:12 AM
LexGX
LexGX's Avatar
I believe all you have to do is get the new dvd with the updated maps and switch it out with the one in your car. Its located under the passenger seat i think. Or the Driver's seat, i can't remember correctly.
Old 10-27-08, 08:34 PM
sryan423
sryan423's Avatar
Default Navigation Update
Can I get the disk from someone other than the dealer?
Old 10-28-08, 05:14 PM
squeege
squeege's Avatar
See above: click on 'SPONSORS' find Sewell Parts & use the discount code.
I updated my disc when the 2008 disc came out. The player is under the front passenger seat.
Squeege
Old 10-31-08, 03:37 PM
feldsqx4
feldsqx4's Avatar
I have a similar question. I just bought a 04 GX470. I have nav and rear dvd. Is there a way to load software or new menus to mimick the 05 GX or even later or can you just update the maps? Also, is there a way to get the DVD to play on Nav screen as well. Looking for some expertise as I'm new to this board. Thanks guys.
Tim
Old 10-31-08, 03:40 PM
feldsqx4
feldsqx4's Avatar
Oh, and also if there is way to "trick" the car into letting you type addresses in the nav while driving, super annoying.
Old 10-31-08, 05:36 PM
sickntired
sickntired's Avatar
fedsqx4:
Nav DVD upgrades usually only update the maps. Sometimes it may add 1 feature, but usually there are no new features. They never change the way the menus look (ie, to look like newer generation NAVs).
Old 10-31-08, 08:49 PM
squeege
squeege's Avatar
sick answered your first question.
2nd question: press Menu, then DVD in upper right hand corner.
Then Left upper, left lower, left upper, left lower, right lower (all blank areas)
Then hold Override until it highlights.
Must be done each time the car is started.
squeege
Old 11-06-08, 10:23 AM
SilverLady
SilverLady's Avatar
My dealer claims they recalibrate the nav as part of the new DVD installation procedure.
Anybody know if that makes any sense?
Old 11-06-08, 04:53 PM
squeege
squeege's Avatar
I have no idea what the dealer means by recalibration. I removed the old dvd and placed the new dvd.
squeege
Old 11-09-08, 06:16 PM
jacksonian
jacksonian's Avatar
I think there's a menu option for that, it just recalibrates the GPS locator, you can do it yourself I'm pretty sure.
It's embarrassing that dealers would charge for the "installation" which is the same as inserting a cd into the player.
Old 11-09-08, 06:27 PM
jacksonian
jacksonian's Avatar
Is Version 7.1 the latest?
Old 01-08-09, 09:39 AM
Ntwrks1
Ntwrks1's Avatar
Default Latest version of Nav disc for 2004 GX470 (Gen 2-3?)
That was the question I had also - is the latest Navigation update DVD for the Gen 3 Nav in the '04 GX470 the Gen 2-3 v7.1 86271-33036 464210-0930 Disc?
Thanks,
James
Old 01-08-09, 11:50 AM
NexVision
NexVision's Avatar
The recalibration can be done yourself from within the menu I had to do it after my GPS tripped out from placing my xm unit underneath the antenna. Basically it is a little circle and u position it to your current position and direction takes like 30-45 seconds. The upgrade is as simple as inserting the new disk. The newest available is 8.1 I just got a copy of 7.1 but as it turns out now my truck maybe getting totalled by the ins company since there tired of fixing it again and again. If thats the case I will be selling the 7.1 disk for $100 that I got less then 2 weeks ago for $110 should know a little more in the next day or so.
Old 10-20-10, 06:40 AM
4everlexus
4everlexus's Avatar
Default Nav Override?
squeege
Hi..
I remember I used to be able to do this BEFORE I upgraded to version 9.1 by doing that in the Volume area. I just tried your sequence and no luck.
Anyone?
Thanks...
Quick Reply: GPS Navigation Update
