IS F front rotors
Old 11-17-08, 01:58 AM
  #31
itazura
itazura's Avatar
VERY NICE!
you think this would work with supra tt calipers w/custom brackets?
Old 11-17-08, 02:53 AM
  #32
lexforlife
lexforlife's Avatar
wow , i stand corrected ... they seem to mount perfectly .. i guess the ls430 have a diff mounting position
this should turn out great then
Old 11-17-08, 03:17 AM
  #33
lexforlife
lexforlife's Avatar
oh btw
heres a pic of the ls430 mounted on 13.25 in rotors ..you can see the 1in ring around close to the base of rotor
so it was not a disbelieve post it was simply questioning based on my own exp with retro fitting
so again i stand corrected and again great job they should really look outstanding
Old 11-17-08, 07:34 AM
  #34
5sp_jzz30
5sp_jzz30's Avatar
Originally Posted by chrispy
Looks great! You should have a few extra brackets made for anyone who wants to do this mod.
lets not get into that conversation. he is not a forum vendor thus this type of conversation will get this thread locked and/or deleted. i had this happen to me when i machined my own steel rack bushings and posted on here.
to the OP. it looks good. so what is the radius from center to the outside of the caliper? i wonder if i can get my 18x10 enkei's to clear.
Old 11-17-08, 08:45 AM
  #35
//LRD
//LRD's Avatar
Originally Posted by itazura
VERY NICE!
I'll be test fitting an SC with TT brakes this evening and I'll post the results asap.I would think it would fit better with TT or the some.
Thanks for lookong outJust went and check the radius and it about 8 inch give or take a couple of mm
Old 11-17-08, 03:20 PM
  #36
YeA 2jZ
YeA 2jZ's Avatar
hey man this is coming out great good luck i'll be pm you soon
Old 11-17-08, 05:31 PM
  #37
gabegtz84
gabegtz84's Avatar
I love this build this is some great ideas guy, I wonder what other parts I can strap to my SC300?
Old 11-17-08, 09:44 PM
  #38
5sp_jzz30
5sp_jzz30's Avatar
post some drawings of the bracket. if you dont have CAD or some other modeling software draw it on paper, scan it, and post it
Old 11-17-08, 10:10 PM
  #39
//LRD
//LRD's Avatar
Here are some step by step photos
cardboard and it's many uses
here is how the template looks mounted
just to show you how close the mounting ears are to one another. If it wasn't for the extra 1.80in of rotor mass it wouldn't of work.
is a side by side of the rotors
a before shot
and the TADA shots
I hope this will plant a seed in your heads.If any of you who are thinking about do this mod.It's fairly easy
Old 11-17-08, 10:33 PM
  #40
rwdanthony
rwdanthony's Avatar
does those brackets actually withstand the braking power? it makes me feel weary like they can just rip off under hard braking.
looks good though!
Old 11-17-08, 11:27 PM
  #41
FormosaSC
FormosaSC's Avatar
it looks like ls400 calipers lol
if id didnt know the rotor size, that's what i would think.
Old 11-17-08, 11:55 PM
  #42
itazura
itazura's Avatar
looks good though!
those are the mach up brackets like he said. look at the cut out.
they are ls400 calipers.
Old 11-18-08, 07:10 AM
  #43
//LRD
//LRD's Avatar
looks good though!
Thanks man I'll be sure to post the pictures of the bracket once their made.
[QUOTE=itazura;4014274]those are the mach up brackets like he said. look at the cut out.
Thanks ^^^^ try to test fit the TT brakes yesterday.But we couldn't get the bolts off.Will try again today.Looking at them closely I think they'll work
Old 11-18-08, 06:39 PM
  #44
YeA 2jZ
YeA 2jZ's Avatar
Hey do you think with a 15mm spacer it will clear stock 18" wheels
Old 11-18-08, 06:51 PM
  #45
5sp_jzz30
5sp_jzz30's Avatar
dude you told me that right now with those rotors it is about 8" from center to our edge of the caliper. i went to measure my enkei wheels today and there is absolutely no way in hell that would work. with 19's it would but 19's are retarded for tracking and tires are through the roof compared to 18's...especially for r-compounds.
i think ill have to stick to my current setup and make brake cooling ducts to compensate for smaller rotor.
Quick Reply: IS F front rotors
