housing for passenger side mirror
Old 01-17-09, 10:19 PM
pooker
pooker's Avatar
Default housing for passenger side mirror
where and if can I buy housing for passenger side mirror>? Any help, direction will be appreciared
Old 01-18-09, 08:38 PM
Dave Mac
Dave Mac's Avatar
I'm not sure that is possible - maybe an auto salvage yard for the whole mirror assembly. I don't believe the housing is a separate part.
Good luck, a mirror assembly from Lexus is not cheap or course.
Dave Mac
Old 01-18-09, 09:01 PM
VegasIS300
VegasIS300's Avatar
The whole assembly costs 469 bucks on carson's OEM part catalog.
Old 01-24-09, 07:20 AM
Dave Mac
Dave Mac's Avatar
I see there is a complete mirror assembly for sale on ebay right now. The color is black I believe. Several days left and the openning bid was 99 cents.
Dave Mac
Old 01-24-09, 08:37 AM
RXGS
RXGS's Avatar
I am pretty sure there are some used mirrors for sale in the es classifieds section, check there
Old 02-08-10, 07:51 AM
jkutti2000
jkutti2000's Avatar
ANY LUCK ON THIS ONE... i was backing out of the garage and I hit the side. the mirror works fine. but the plastic is shattered. I think I just need the OUTER HOUSING.. not the complete mirror which Costs a fortune.
so where can I get one of the same color. (silver) and instructions to INSTALL IT ?
ALSO. if I dont have side lights. can I upgrade mine to have side lights. how will it work. do we have to connect extra wires. is it a DIY job or complicated ?
Old 02-08-10, 07:49 PM
SickES350
SickES350's Avatar
try some aftermarket one, you'll get a blinker on your side mirror also i believe.
Old 02-09-10, 04:04 PM
acdapast
acdapast's Avatar
hopefully someone can do a real DIY for taking out the whole mirror assembly out
Old 02-10-10, 06:34 AM
ESBob72
ESBob72's Avatar
Having replaced two complete mirror assemblies on the ES350 I want to warn you that (in 2007-2008) there are two sizes of mirrors for the ES350. The one with puddle lamps, heated mirros etc. is taller than the mirror assembly on the base model. Replacing the mirror assembly means taking the door panel loose and removing the two nuts and plug that go to the mirror base. To replace the outer housing you only need to remove the mirror by pulling up and out on the bottom of it and unplugging the wires for the heater and then removing the screws that hold the housing together. You can buy the housing that matches your paint by bringing your VIN to the dealer.
Old 03-08-10, 11:10 AM
jkutti2000
jkutti2000's Avatar
http://cgi.ebay.com/ebaymotors/2007-...ht_4399wt_1165
I want to buy these.. however.. how do I get them painted..also my side mirrors dont have the side lights.. how do I get them installed.? is the wiring just a plug in?
my color is tungsten metallic.
Bobjann
06-23-14 12:50 PM
MsbTTSupra
03-14-14 04:00 PM
spidds
06-17-08 03:18 PM
minh
GS - 1st Gen (1993-1997)
06-08-04 09:16 AM
Quick Reply: housing for passenger side mirror
