How to turn off Oil Maintenance Warning and Light
Old 01-21-09, 12:00 PM
ehryciuk
ehryciuk's Avatar
Default How to turn off Oil Maintenance Warning and Light
Does anyone know how to turn off the oil maintenance warning message on a 2007 ES 350?
Old 01-21-09, 01:04 PM
flowrider
flowrider's Avatar
Received 1,828 Likes on 1,290 Posts
Search is your friend:
https://www.clublexus.com/forums/1893761-post15.html
Lou
Old 01-27-09, 09:12 AM
ehryciuk
ehryciuk's Avatar
Default Search is not my friend
That method does not work with my 2007 ES 350. It does not have a reset button and an odo button. It has one button that cycles thru odo, Trip A, Trip B, which zeroes out the trip meters when held down. There is no separate "reset" button.
Anyone else?
Old 01-27-09, 09:33 AM
LexBob2
LexBob2's Avatar
The procedure is on page 287 of the Owners Manual under "Changing the engine oil (USA only)". Good luck...
Old 01-27-09, 11:06 AM
Socal2
Socal2's Avatar
To reset oil maintenance light, follow these steps:
1. Set trip to A by pushing in the stem under the speedometer.
2. Shut off ignition.
3. Press in stem and hold as you push start button twice (do not put foot on brake).
4. After seeing a row of 0000000 from odometer, release stem.
5. Start ignition, it will go through check and light will be out.
Muhammad33 (04-06-24)
Old 01-29-09, 11:03 AM
cmac747
cmac747's Avatar
Default Oil Maintenance Light is now off
That worked on my 2007 ES 350. Thank you. Also, some web posts say to set trip to ODO, but it must be set to A or it won't work!
marky2mark
05-04-11 12:59 PM
kennyboy
05-02-11 03:37 PM
MARINE61
02-03-10 09:31 AM
bozer
03-06-09 08:05 PM
ehryciuk
01-26-09 08:08 AM
Quick Reply: How to turn off Oil Maintenance Warning and Light
