99 GS300 "Brake" "VSC" "ABS" "VSC OFF" light on
Old 01-27-09, 07:40 PM
mercado
mercado's Avatar
Default 99 GS300 "Brake" "VSC" "ABS" "VSC OFF" light on
Hey guys I have a 99 GS300 with the BRAKE ,VSC, ABS, AND THE VSCOFF light on and the brake pedal is really hard. You really have to step on it hard to get it to stop. There are no codes present. Does anyone know if it could be a common problem.
Thank you in advace...
Old 01-27-09, 11:45 PM
SorrGwa
SorrGwa's Avatar
if the abs light goes on, it wil automatically turn off ur VSC and tell u that ur VSC is disabled because the VSC system uses ur abs to control the spin.
if ur brakes feel weird, get them checked, could be ur master brake cylinder, could be the abs sensor. its hard to say since u said u got no cel.
Old 01-28-09, 05:28 PM
mercado
mercado's Avatar
The brake pedal gets hard and i can't get it to stop, and theres a loud and annoying continuous beep. I was able to retreive the ABS sys codes here they are: C1223 ABS SYS FAULT, C1256 ACC. PRESS LOW, C1252 HYDRO-BOOST PUMP MOTOR FAULT, and C1251 PUMP MOTOR LOCKED. I clear the codes and the fist two come back right away i don't even have to drive it.
Old 01-29-09, 05:22 PM
AshburnM3
AshburnM3's Avatar
check your brake fluid !!!
Old 07-07-09, 07:11 PM
jonnydclar
jonnydclar's Avatar
Default GS300 brack master cylinder question
Hi, I just bought a 99 GS300 with the same lights on only my brake pedal is very soft. Can you tell me how you got the brake codes off the computer and if you changed the master cylinder to cure it?
THanks,
Jonathan
Old 07-07-09, 07:18 PM
GS300ToM
GS300ToM's Avatar
your booster is screwed..!!!!!! but check your fluids as well
Old 07-07-09, 07:33 PM
jonnydclar
jonnydclar's Avatar
Thanks. I assume the soft pedal (gets harder when pumped) means there is some leakage past the piston. The current booster shows markings from a junkyard. Best case they bought a crappy booster. The seller showed a receipt from the toyota dealer where the dealer commented "booster is junk, came from a junkyard." My fear is something else is wrong with the car causing it to EAT boosters. Is this possible? Should I check anything before spending the $$$ for a new one?
Old 07-10-09, 07:22 AM
joshoowa
joshoowa's Avatar
AbS sensor could be busted..no CEL code you need a special ODB2 reader for that
Old 07-13-09, 10:33 AM
jasonlee
jasonlee's Avatar
i had the same problem after installing my coilover, check behind the front rotors and see if the abs wire is bent or too tight
Muggeth (02-22-21)
Old 06-11-12, 08:59 PM
boltfan
boltfan's Avatar
I have the same issue as the original poster, but add the loud constant beep. Brake pedal is stiff and barely slows the vehicle.
Dealer previously told me (one year ago) the master cylinder needed to be replaced based upon the codes.
Any suggestions on used parts if that is the case?
Old 06-18-12, 09:28 PM
jamesz0rs
jamesz0rs's Avatar
i have the same problem but it only comes on when i gun it and or its raining. once i turn my car off and back on its gone.
Old 04-13-13, 09:09 PM
808Garage
808Garage's Avatar
Default VSC/ABS/VSC Off Lights On
I have a 98 Lexus GS300. I just replaced the inner lower control arm bushing. Now when I start the car, the VSC/ABS/VSC Off indicators are on. I scanned for a CEL code but no code is found. I test drove the car and it runs fine even up to 100mph. How can I get this reset or resolved. Thanks!
Old 04-13-13, 10:39 PM
amichie
amichie's Avatar
I did this before and you need to do a zero point calibration to clear the lights. Do a search on how to do a zero point calibration. I got my instructions off Bahamutcars that has now been shut down but I'm sure there will be a link somewhere.
Old 04-21-13, 05:56 PM
Richard7
Richard7's Avatar
I just bought a 98 gs300 and i tried taking the vsc off but it wont.... I was checking if all the button works and so far thats the only thing. I tried hitting the button a few times but it wont work... Does anyone have an idea how to fix that? Or it might not be hooked up ?
Old 04-22-13, 02:41 PM
Splurge
Splurge's Avatar
Sounds like your booster is bad, just replaced mine,
Quick Reply: 99 GS300 "Brake" "VSC" "ABS" "VSC OFF" light on
