Noise when press gas pedal
Old 02-25-09, 12:24 PM
rustylexus
rustylexus's Avatar
Default Noise when press gas pedal
when im coasting down the road and i press the gas pedal to accelerate a loud noise comes from under the car. i also hear it when im sitting still on the brakes and i shift the transmission from reverse to drive. anybody heard of this problem?
Old 02-25-09, 12:35 PM
qewani1
qewani1's Avatar
http://www.google.ae/search?hl=ar&q=...&meta=&aq=f&oq=
Old 02-25-09, 12:38 PM
Kaydee
Hacked CL to become a Mod
Kaydee's Avatar
what kind of noise? ticking? tapping? hissing? high-pitched? give us more info...
Old 02-25-09, 12:43 PM
rustylexus
rustylexus's Avatar
its like a hitting sound like a clunk. it sounds to me like something maybe a u-joint is loose. it doesnt make the sound if i very easily press the gas pedal to accelerate.
Old 02-25-09, 01:27 PM
Lexs400
Lexs400's Avatar
Is it a loud noise or something that you'll have to turn down the music to hear.
also is it noise or is it a thump that you "feel" when you press the accelerator ? is it comeing from the rear ?
Old 02-25-09, 01:57 PM
Bali26
Bali26's Avatar
Motor mounts
Old 02-25-09, 06:11 PM
Rocan
Rocan's Avatar
thats the engine going "vrooom"
xD
Seriously its probably the motor or tranny mounts
Old 02-26-09, 10:19 AM
rustylexus
rustylexus's Avatar
you can feel it when it happens even with the music up. its as if something was loose in the drivetrain somewhere. im just trying to see if its common and what it is
Old 02-26-09, 07:35 PM
Rocan
Rocan's Avatar
must be the tranny mounts...
cheap fix, albeit time consuming, if im not mistaken
Old 03-23-09, 01:50 AM
ucfjon
ucfjon's Avatar
it could be:
- the flex disc between the driveshaft and the transmission
- the flex disc between the driveshaft and the rear diff
- transmission mounts
inspect these rubber parts
Old 03-23-09, 01:22 PM
JBrewster
JBrewster's Avatar
Nah the transmission mount is easy, it's the motor mounts that are a pita.
Old 03-23-09, 02:28 PM
python
python's Avatar
sitting still and u think it might be a u-joint? lmfao....problems like this are impossible to diagnose on forums, it could be something like a loose muffler or u could have ran a cat over and it squirming around under there trying to get free! take it to a shop and let someone put it on a rack and/or test drive it
jivoz123
07-19-17 09:52 AM
innomind
ES - 6th Gen (2013-2018)
02-24-15 07:27 PM
Yurka
01-22-12 01:02 PM
tcd300
Performance & Maintenance
10-17-08 08:14 PM
Legends6spd
06-16-05 01:09 PM
Quick Reply: Noise when press gas pedal
