DIY: IS-F front brake pads
Old 03-22-09, 05:50 PM
caymandive
11 Second Club
caymandive's Avatar
Default DIY: IS-F front brake pads
Well thanks to the the DIY that JavyLSU posted for the IS350 and lobuxracers's tips, I've done a DIY for replacing the front brake pads on the IS-F.
If you are looking for a DIY on replacing the rotors click here.
It takes about 15-20 minutes per side as long as you are not sitting there taking pictures.
AndrewISF (02-26-17)
Old 03-22-09, 05:51 PM
caymandive
11 Second Club
caymandive's Avatar
- Now double check everything including your brake fluid reservoir cap!
- Put your wheel back on and properly torque the lug bolts
- Embed the pads to the rotor properly. I did several 60 to 10mph stops.
- Clean up and have a beer or two with the money you just saved.
The following 2 users liked this post by caymandive:
AndrewISF (02-26-17), isfvss (10-26-17)
Old 03-22-09, 06:31 PM
LexISguy
LexISguy's Avatar
Thanks for the info. What brand of brake pads?
Old 03-22-09, 06:53 PM
montgb
montgb's Avatar
Awesome write-up, Cayman!
Old 03-22-09, 07:21 PM
ArticKnght
ArticKnght's Avatar
This will be great for future reference
Old 03-22-09, 07:33 PM
LEXUSF
LEXUSF's Avatar
nice job! thanks for the pictures! helps me since im slow!
Old 03-22-09, 09:42 PM
BigMikeISF
BigMikeISF's Avatar
Saved for future reference! Great stuff Cayman! Thanks!
Old 03-22-09, 09:59 PM
javyLSU
2IS OG
javyLSU's Avatar
Great job James! When you told me you were going to do the DIY like mine you weren't kidding... Glad my tips today could contribute in a small way to your DIY.
Javier
Old 03-22-09, 10:29 PM
sclx
sclx's Avatar
Quick tip on pushing the pistons back instead of using a screwdriver 6 times, and possibly marking the edge of the rotor in 6 places, just use the old pads. Instead of taking the old pads all the way out, only remove them half way, then push on the outside of the pad, wedging the back part of the pad against all 3 pistons at the same time. Do this on each of the old pads, pushing the outside edge of the pad towards the centerline of the rotor so the back of the pad pushes against the pistons. Do this until they are flat on the inside and the new pads should be able to slide into place.
Desi
Old 03-23-09, 04:24 AM
caymandive
11 Second Club
caymandive's Avatar
Desi
Yup that should work too, but I forgot to mention that I put some shop towels between the rotor and the large screw driver to prevent marking the edge of the rotor.
Shoot me a PM.
Old 03-23-09, 07:12 AM
PHXF
PHXF's Avatar
any less dust? you should be able to tell once you leave your driveway.
Old 03-23-09, 07:18 AM
caymandive
11 Second Club
caymandive's Avatar
I can't comment on the pads to the full extent yet until I rack up some miles on them, but will report back by the weekend. I can tell you that the groans are gone (the noise the brakes used to make when creeping along at uber slow speeds such as in parking lot traffic), they are still plenty grippy and they don't have the sudden catch that the OEM pads had which makes for a more tolerable ride and with a baby on the way I'm sure this will be a good thing.
Old 03-23-09, 08:43 AM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Thumbs up
Very Nice Work James!!!
There is no harm in posting the brand of pads you installed..
Also, are the OEM Rear pads just as dusty and/or noisy as the OEM Fronts??
Joe Z
Old 03-23-09, 09:16 AM
caymandive
11 Second Club
caymandive's Avatar
Joe Z
Unfortunately the pad brand is apparently unique to the site I purchased them from. I asked them specifically what brand they were and all they would tell me is the pads are their own brand, which I thought was odd as someone has to manufacture them. The guy told me if there are questions about the pads to have people call him, so for those interested in the ceramic pads send me a PM and I'll give you the contact info. Be forewarned though that they have some improving to be made on their phone/social skills. They always sound shrewd when I talk to them.
Joe, to answer your question the rear pads have never given me any kind of noise. They also shed about half as much dust as the fronts being they are in the back.
Old 03-23-09, 09:50 AM
Joe Z
Joe Z's Avatar
^^ Thats interesting about the new pads..
Thanks for the info on the rears..
Quick Reply: DIY: IS-F front brake pads
