Gas pedal sticking at wot
Old 03-30-09, 01:26 PM
IonFeright
IonFeright's Avatar
Default Gas pedal sticking at wot
I was driving home the other day and for the first time in months I decided to go wot. Pushed the pedal to the metal and when I went to shift the gas pedal didnt come back with my foot. Instead it sat at wot for 2-3 seconds until I was able to kick it free.
Went wot a few more times with same result. Doesnt get stuck every time but maybe 50% of the time
Took it easy from there and checked on it when I got home. Everything looked fine accept I now have a cel. It doesnt seem to be catching on the carpet, or anything in the engine bay.
Any ideas??
Old 03-30-09, 08:05 PM
RyanV
RyanV's Avatar
Weird, have you tried pulling the throttle cable to WOT at the engine to see what the cable is doing? Maybe it is binding up.
Old 03-30-09, 09:02 PM
chargedsc
chargedsc's Avatar
man check the throttle body mine was doing that it ended up having carbon build up and it was sticking at wot it might just need a good cleaning
Old 03-31-09, 11:51 AM
TheMole
TheMole's Avatar
Man thats a scary thought to have your gas pedal stick. Seems like something with the cable or throttle as previously mentioned. Hope you fix it soon.
Old 03-31-09, 01:15 PM
5sp_jzz30
5sp_jzz30's Avatar
clean your throttle body. it has a lot of crap on it and causes it to stick. 95% of the time thats the problem. best way is to take apart the throttle body and clean it. most of the time simply spraying brake clean in there will cure the problem.
Old 03-31-09, 01:19 PM
IonFeright
IonFeright's Avatar
Thx for the responses guys. Ill take a look at the tb today and see if thats it.
'99 SC 400
05-25-23 09:36 PM
gm991
02-24-11 06:14 AM
Dueces
12-01-10 10:18 AM
Luxor
14
11-11-10 12:36 PM
Will400
10-12-05 01:48 PM
Quick Reply: Gas pedal sticking at wot
